swapping back - 912E conversion to stock
So my 77 Targa was converted to a 912E. It is running all the 912E bits, 923/02 Tranny, special rear sway bar and mounting block (welded mounts). The 914 is fine, but I want a 6 back in the car. I am trying to decide if I need to remove the 923 transmission to get everything to work properly or I can mate the 2.7 (or 3.0) up to it and have gear ratios like the 73 RS. Help me out Guru's what things will I need / watch out for if leaving the 923/02 in my 77. Thanks!
Seemed to be a problem with the 923 mainshaft not being compatible with the 6cyl motor. Can't recall the exact problem, perhaps someone with better knowledge will reply.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I am hoping it is only a matter of the correct clutch package. Didn't early cars mate to the rough splines? 70-73?
I think if you can keep the current clutch parts, it will work. But this is a weak work around. You will be happier with a 915.
gearhead
Rubbish. There's nothing weak about it. The input shaft is splined like a 914 and requires the esrlier clutch stuff. Internally it is a 915 gearbox.
Under the radar
What you mean is the '70-'71 disk?
Ok so if i get a 70 - 71 clutch disk package it will bolt up to a 2.7/3.0 flywheel and everything will be good.
Is there anything needed for mounting that may be different? Engine and transmission mounts. |
gearhead
No, I said what I meant. The 912E's 923 gearbox uses the same 215mm clutch assembly that a 914 or 1969 901 uses. It does NOT use the 225mm 70-71 911 gearbox style clutch assembly.
As long as someone uses one of the 6 bolt 911 engines everything in the car can be retained when swapping the car back. That's part of why you see so many 914-6 conversions using the 2.7. It's fairly straight forward on the clutch piece of it, whereas the later 3.0 and up engines have a different crankshaft bolt pattern.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Now I understand.
Thanks a lot Matt! |
Under the radar
Matt, so you are saying that if one installed a 2,7 or 3,0, with a flat flywheel, that a 225mm pressure plate and disk would not fit in the bell housing of the 923?
So the 923 trans won't accommodate the later 225mm pull type pressure plate?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 10-07-2018 at 09:43 AM.. |
gearhead
Gordon,
I don’t know anyone who has ever tried. What I’m saying is that every 912e I’ve seen turned into a 911 and every 923 gearbox I’ve seen used in a 914, used the stock clutch. How would you address push versus pull?
Under the radar
Matt, I guess there are a couple of things to consider.
Since all the pressure plates on 911s are the pull type from '70 on and mate to a flat flywheel, I assumed that set up would work in the 923 trans. I am assuming the release mechanism is the same in the 923 as in the 915. Maybe that is not the case? For example when I changed from a 901 trans to a 915 trans in my '71 911 I could use the PP and flywheel that was on my 2,2 motor. I only had to change the disk and the throughout bearing to match the newer trans. So for example if the OP installed an SC motor couldn't he use the PP and flywheel from the SC, but use a '70-'71 disk? The '70-'71 disk is 225mm but has the smaller spline as was used on the 901 trans. I am assuming that the 923 and the 915 share the same release arm.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 10-07-2018 at 11:01 AM.. |
gearhead
Under the radar
So the release arm is different on the 923 compared to the 915. I would guess that that could be changed? The shaft is the same? Change the fork and the arm on the bottom? Possible? Otherwise using an SC motor would require a custom flywheel?
From 1970 on all pressure plates are matched to
A flat flywheel The 923 mainshaft will be the same clutch. 215!or 225 pre 72 You probably change guide tube then a 915 pp and TOB with a 911 disc should work Bruce |
915 from an 86
That guide tube is already larger than Matt s
Picture Bruce |
901
Gordon. I don’t see a. Reason for a custom flywheelfor a 3.0 because except for bolt holes every thing is the same
Bruce |
Bruce
The guide tube has no affect on the PP, clutch, flywheel. It is solely for the TO bearing correct? So that will all stay the same on the 923. Are all surface area of the TO bearing made the same, meaning they will all touch the fingers at the same point no matter which guide tube you use? |
