Speedometer / Odometer - One problem or two?
About a week ago my speedo needle started dropping to zero for a few moments, then returning to current speed. Operation was smooth, just would occasionaly go flat.
Then today, the odometer quit incrementing a few tenths after rolling over 999.
After reading quite a few threads and tech articles, it sounds like the odometer might be the stripped gear problem.
I am not totally familiar with how the speedo works, are these two issues possible related, or is this two separate issues?
1984 M491 Coupe
2014 Cayman S
Old 10-11-2018, 03:23 PM
Is the speedo still working? If so the odo failure is likely a stripped gear.
Old 10-11-2018, 08:51 PM
Speedo works, but intermittently stops for a few seconds.
Odo is not working at all, so it seems like the likely cause is gears.
Is there a likely cause for the intermittent speedo?
Old 10-12-2018, 01:30 AM
It might well be the speedo sensor, or a bad connection.
Mine started acting "wonky" and I looked for connections. The connector in the back of the tunnel had one wire that was just hardly touching. I simply pushed it together and all is well. I love free fixes.
Old 10-12-2018, 06:03 AM
