Fresh air blower fan switch
I've just had my fresh air blower apart (83 sc) to lubricate as it was squealing.
Once finished, I plugged it in to give it a dry run and it was smooth, quiet and even appeared to rev faster.
So I put every thing back together and then found out the fan switch lever at the dash would not move from the off position. It somehow appears to be hung up for whatever reason. It looks as though I'll have to remove the complete heater control unit from the dash to see what is preventing the lever from moving.
Finally, my question is, how do I go about removing that control assembly from the dash?
Thx
Hugh c
Old 10-19-2018, 12:05 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
sliders.
Thx
Hugh c
There are two attachment points from the backside of the sliders assy.
However, I suspect that somehow one of the Bowden cables are
not routed correctly, and binding.
Have a look under the dash while someone tries to work the slider.
Also, perhaps one of the clamps that holds down the cable has come loose.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-19-2018, 01:17 PM
If you didn't mess with it, why would anything change there? Probably related to what you did with the motor linkage/flaps or cable hookup. disconnect the cable at the motor and see if it slides then.
206 637 4071
Old 10-19-2018, 01:24 PM
This. ^^^^
Also you will likely discover that the fan will work for a short time but soon be making noise again. Most of the time the only cure is to replace the fan motor. Silly expensive and pretty poor quality. It is what it is.
Old 10-19-2018, 02:18 PM
Thanks guys,
The only cable that I removed is the one that opens/closes the flaps on either side of the motor enclosure and I think I replaced it properly. The flaps open and close together as I move the lever at the dash.
Looking at a pic of the speed control switch (the one in the dash) I failed to see how it would have any effect on any of the cables as it doesn't appear to be attached to any of the cables. It appears t be no more than a three position switch.
Both lower levers at the dash move very freely, ie no binding.
The speed control lever however is stopped hard in the OFF position. During the repair I used the speed control switch once and that was to see how well the motor ran after I cleaned and lubed it.
I'll have to remove everything again tomorrow to see if I missed anything but I'm quite certain the switch is binding somehow in the dash.
Hughc
Old 10-19-2018, 05:33 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
It is a really simple system, google some images and you’ll be able to reach under dash and pull on some things
Old 10-19-2018, 05:57 PM
Wildman Emeritus
Subbed
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-20-2018, 07:48 AM
Only one cable goes to the fan box, the upper slider. As it moves to the right, the fan speed contacts come into play.
206 637 4071
Old 10-20-2018, 08:37 AM
Thank you John. I think I got it sorted out.
Before going to bed last night I decided to have another look at it and pulled the air blower box out again. The only thing that appeared wrong was the crank position for the flap on the passenger's side of the air box. I repositioned it, screwed everything back together and voila it all worked as it should. So I can assume the crank position was causing the problem
Thanks to those that replied with their suggestions.
Hughc
Old 10-20-2018, 02:15 PM
