toddu's Avatar
Installing fixed quarter windows
Not sure what the trick is here. I have new (Porsche) seals, trim is in place. I've soaped everything up and I can't get the window to push far enough into the opening to get roping to do anything. If I get the top in far enough, the bottom sticks out too far. I really can't get the bottom to push in enough to attempt the opposite. It seems as if to get things in the front grove correctly the top kind of seats first.
Even with the top of the gasket touching the pinch weld, when starting to rope it in it's not pulling the window in at all, so it's just barely flipping over the seam.
I'm attempting to rope in top ~ 2 inches from corner and then down the flat side. Flat side seems ok, but the rest, forget it. So frustrating!!
Any pointers?
Todd
'81 SC
Old 11-21-2018, 10:51 AM
Cars and Cappuccino
tdw28210's Avatar
Todd,
If I wasn't away I'd offer to come by and help. I am facing the same thing soon in getting all the glass back into my coupe project.
Good luck!
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 11-22-2018, 05:56 AM
You Need someone to push from outside.
Old 11-22-2018, 06:01 AM
toddu's Avatar
Yes, I was pushing with all my might (wouldntday I’m a slouch) and my kid was pulling the roap. There is some left over dum dum that might not be helping. The gasket is so tight, not sure why it’s necessary.
TDW - what part of NC?
'81 SC
Old 11-22-2018, 06:17 AM
Cars and Cappuccino
tdw28210's Avatar
South Park area of CLT.
Old 11-22-2018, 06:46 AM
Old 11-22-2018, 07:11 AM
Soak seal in hot water for a bit, use 12 gauge wire romex or something similiar diameter. Also a stick or paint can opener.
Old 11-22-2018, 07:14 AM
toddu's Avatar
Yeah, wondering if my rope is too thick and adding to the resistance.
Todd
'81 SC
Old 11-22-2018, 09:53 AM
Simple Green is slippery. May help the rubber slip in. We use it for mounting Kart tires.
Derrick
Old 11-22-2018, 02:01 PM
Formerly known as Syzygy
Canada Kev's Avatar
Years ago a couple of us had to change out all the windows in a Prevost motor coach. That's like a dozen windows per side. After the first couple being a real bear, I thought it might be an idea to lube the seals with something that worked great for me on mountain bike grips: WD-40. We got the R & R of each window down to less than ten minutes each. It left quite a film on all the glass, but it was a small price to pay cleaning that off.
Now I'm not suggesting you use WD-40, but a good water soluble lube will make your job far, far easier.
Kevin
Old 11-22-2018, 06:02 PM
175K911's Avatar
I just installed my passenger side quarter window. Plexi window in the 993 seal. With my wife pushing from outside, nylon rope and Simple Green, took maybe 30 minutes, though we struggled with the upper front corner for a good 25minutes. Turned out my Perlon headliner was in the way, had to cut back the material for the seal to sit right. Plus the roll cage bars made working in the upper corner challenging. When we do the drivers side tomorrow I’ll start in the upper front corner.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 11-23-2018, 10:51 AM
