I had a girlfriend that like you, contributed nothing and criticized everything. |
I like the VW. Boiled linseed oil is a bit like a soft varnish, as it will dry up a bit. It can mold over time. Raw linseed oil never hardens.
A lot of guys out east are using a product called Fluid Film, which is made with lanolin, and gets applied every year to all inside panels, crevices, and the underside. Of course the old timers rub would rub kerosene on their tractors, and some still do. I know a guy who has a bucket with sand and kerosene in it. When he is done with the tool, he plunges it into the sand a few times and agitates it. Then there are products like Krown and Corrosion Free, which come from Canada. You can get those in pails or spray cans, and that is the real deal. Ship2Shore would be a step up from that, as a more industrial coating, but Krown and S2S have to be kept from natural rubber like door seals, as they make it swell. Corrosion Free does not. |
Although not a common practice today, before the modern base/clear paints become common, many people cleared single stage enamel paints for more gloss.
I am not big on high solids primers and I use your method of 2 part primer and make that smooth. However, I have finished jobs where a high solids build/sand would have delivered superior results. If I were painting high end cars vs 2002 Camry fenders, I would use the build primer. How is that for walking the fence? Also, used Ospho since the 70's. Nothing I have used leaves bare metal. Neutralize rust? Sure. Leave bare metal, nope. |
Yes Lisa. Fabulous, amazing even in one or two ways. But all that whinging and criticizing got the better of me after ten years.
All I know is what they told me on the course. I'm leaving the rest up to you guys to point me in the right direction with car painting :) |
Rust is like Herpes.
Seems reasonable though in certain applications where perfection is important. |
I guess what I didn’t make real clear when I started this thread is that no painting is taking place after neutralizing the rust. This is a survivor car. I’m going for the look similar to the linseed Vw video. All these yeh yeh posts has me in the mood to break out my Beatles cd.
Survivor car. If the rust isn’t bad just neutralize and don’t give it any more thought. I can’t tell you how many major restorers do this very practice. Suggesting it cannot be neutralized is scientific fallacy.
come on bill, you've called out my doucheyness a time or two over the years and I in hindsight could not disagree with you after a reread. you are the one being the douche this time around. toby |
:eek:
Phosphoric acid will remove the rust and protect the surface. I prefer using this, especially on parts (let them soak overnight). This is great for surface rust
There are other products out there that are rust converters. The ones I've used have a milky white appearance. Turns blackish/purplish when gets in contact w rust. Not sure how it works. Converts the rust somehow and makes it hard. I have painted over it and rust has not come back |
Viking, you're describing POR-15 and similar products that "convert" rust into a black, hard substance. It deteriorates in sunlight so it should be painted if it will be exposed to sunlight. OP, check this out. Note that it needs to be reapplied annually. https://www.eastwood.com/eastwood-patina-preserver-aerosol.html |
Found this "home brew" method too: CLR, Scotchpad and plain old wax.
https://www.youtube.com/watch?v=p6ROUO1dVa8 |
There are some great instances when the Scaglietti yard in the 60s and 70s were making bodies and frames for Ferrari when they simply built the thing, tossed the bare unpainted untreated carcass outside in the elements for months on end until Ferrari decided what they were going to do with it, then painted with plenty of surface rust already having formed but of course 'treated' first with whatever Ferrari-Papal approved treatment, aka the cheapest crappiest whatever they had laying around. The great Ferrari historians, Massini, Nye, etc, all 100% attest to this being common practice of the day by Italians in general, so it was not just reserved to the car industry. There are plenty of pics floating around showing plenty of rusty 'brand new' unpainted bodies just sitting out in the Scaglietti yard so let's all not lose our minds about a bit of surface rust. Only be concerned when it gets overly deep and the metal shows signs of weakness. |
Why not follow the TDS You know directions from the people who actually make the paint.
Sanding primer with 800 grit is a waste of time and doesn't produce a good enough mechanical bond for the basecoat.Probably one of the most knowledgeable painter on here is 962 Porsche I would seek his advice or your local jobber. |
http://forums.pelicanparts.com/uploa...1543848394.jpg |
| All times are GMT -8. The time now is 02:30 AM. |
