Neutralizing rust on paint
There is a 911 currently listed for sale on the pelican boards by Porsport. They have neutralized the rust by some process, thus doing away with the rust and leaving bare metal. Does anyone know what they might have used to accomplish this. I emailed them, but they won't respond. Thanks for any advice!!!
Old 11-26-2018, 07:40 AM
Sounds like a scammer
PCA, POC & SCCA long time Member
Old 11-26-2018, 08:01 AM
Under the radar
Trackrash's Avatar
Ospho or a soulution of phosphoric acid was most likely used. FWIW most any acid will remove rust.
Older 911s, built before '75, will rust from the inside. You should post a picture so those who have de-rusted 911s can give you their opinion.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-26-2018, 08:02 AM
faverymi's Avatar
Neutralize rust my arss. BS.
Cut rust. Weld new metal. Everyone knows it.
Old 11-26-2018, 09:58 AM
I've neutralized surface rust with a product called Evaporust by applying it onto paper shop towels and laying them over the affected area. Seems to do a good job. If it's more than surface, it needs to be cut and welded.
Marv Evans
'69 911E
Old 11-26-2018, 10:26 AM
Geezzz, some of the opinions on this board should be printed not on a screen, but on toilet paper for easier disposal. You don’t take an unmolested 69 911 with light rust and go cutting on it. Thanks to all with treatment remedies.
Old 11-26-2018, 12:57 PM
Eastwood co has a no. of products made to arrest rust/oxidation- they might have an idea ,to answer your question.
But,I think the "cut it out crowd "may be spot on when it comes to a 69 T and "light rust" depending on its current state of repair.
Light rust will, in time become not so light rust ,which then it could be called "Patina ".
Different strokes for different folks.
1979 SC
1986 Carrera 3.6 L+
Old 11-26-2018, 06:48 PM
This stuff works like an acid but also prevents the subsequent flash rust of a raw acid. (Evaporust)
For stubborn rust, I like to rub it away with a scotch brite pad or steel wool.
https://amzn.to/2TMkwFr
www.ahhgaragetime.com
Old 11-26-2018, 10:30 PM
What about Corrosion-X?
Old 11-26-2018, 10:54 PM
Rust can only spread with further surface exposure. If the surface is treated properly, the rust will not be anything more than a light surface corrosion, similar to aluminum oxidation. The treatment chemicals will react with the surface rust and seal the metal from further oxidation.
There is no need to cut, as long as the metal is solid.
I have been using this method on rusted metal for over a decade, and if the surface is protected after treatment, no rust returns.
Old 11-29-2018, 05:49 PM
Banned but not out, yet..
RSBob's Avatar
For light surface rust, Rust Mort which is an acid, works great.
Old 11-29-2018, 06:56 PM
And there's this:
https://www.youtube.com/watch?v=ACGSzBXKONo
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra
Old 11-29-2018, 09:32 PM
Originally Posted by David Borden View Post
That is super cool.
Old 11-30-2018, 02:27 AM
Almost Banned Once
sc_rufctr's Avatar
This car is preserved with linseed oil. Lots of bare metal
- Peter
Old 11-30-2018, 02:40 AM
Hello, What is your method? You nailed it. As long as the rust is neutralized, it will not spread. Added to that, this car will no longer be neglected in a barn, or exposed to rain, snow, etc..... Along with it being in a heated and air conditioned garage, and me being 53 years of age, I don't think the rust will rot my car into the ground during my lifetime.
Old 11-30-2018, 05:27 AM
Bill Douglas's Avatar
I'm just passing onto you what hey said at car painting class.
If it's not rusted all the way through; sand blast the rust particles away.
Clean immediately with phosphoric acid, then wash off with water. The phosphoric acid leaves a small residue which further prevents rust.
Use compressed air to blow any remaining water away.
Wipe down with prepsole or another degreaser.
As soon as possible spray a 2K epoxy primer over it.
Sand down the primer.
Spray base coat.
Spray clear coat.
In a day or two cut and polish the clear coat.
Old 11-30-2018, 07:19 PM
Thanks all for your help and suggestions.
Old 12-01-2018, 04:35 AM
Spray base coat.
Spray clear coat.
If you remove all the rust there's no need for ospho or other rust converters.
You don't sand most epoxy primers.
The only time you would sand an epoxy primer would be if the flash time has come and gone then you would lightly sand for mechanical bond rather than chemical.
Bare metal shoot epoxy or etching primer
Then a high build 2k primer (sand able)
Then a sealer (optional)
Basecoat
Clear if not using single stage.
Old 12-01-2018, 07:27 AM
Basecoat
Yeah yeah yeah.
As mentioned the phosphoric acid leaves a residue that further prevents rust - so a good idea. We 800 grit sanded the 2 or 3 coats of epoxy primer to get a smooth surface. And yeah yeah yeah, no clear if using single stage but isn't that so obvious that you don't need to make a point of it.
Old 12-01-2018, 12:02 PM
Yeah yeah yeah.
Wouldn't let you paint my lawnmower yeh yeh yeh.
Old 12-02-2018, 06:22 AM
