Angry side mirror question
1987 carrera...
My RHS side mirror was hit while backing out from my garage....and is hanging on the door by its electrical wires. the whole mirror and its base were not damaged and neither the car door.
I can not figure out how is the mirror attached to the door...can someone explain or even better show picture of a part that does the trick. The Bently book show schematics of how to take the mirror apart but no reference to how it is attached to the door.
Old 11-30-2018, 01:04 PM
proporsche's Avatar
Hi david
it is not a big deal to rattache the mirror.
1st you have to remove completely your door panel
2nd ..loosen the bolt with little hook and insert it into the door mirror bracket on your door.
number 6c slides on the bolt number 14 that makes the mirror tight...the little hook goes to no.12 tight
1985 911 with original 502 191 miles...808 198 km
Old 11-30-2018, 01:15 PM
David - a photo might help people give suggestions. For instance, is part 6B in the diagram above still attached to the door?
1988 911 Carrera, M491 Cabriolet
2016 Cayenne
Old 11-30-2018, 01:19 PM
mirror
megerian, 6b is not attached to the door .
proprsche, where is #12 located, is it a metal piece or the holes in the door?
Old 12-01-2018, 03:40 AM
proporsche's Avatar
hi David
yes ,the 12 is attached to the door by rivets-from inside It is a reinforcement.The whole mirror assembly goes on it with those two horn on bottom of 6.Then use an allen i think 5mm and by turning 14 the little hook will latch onto the 12...
Ivan
Old 12-01-2018, 03:47 AM
mirror
ALSO... i DO NOT SEE #6C, It probably broke off and fell in side the door.
there is , however, a broken nut still attached to the screw inside the base...do you think this is the nut that was attached to 6c?
Old 12-01-2018, 03:51 AM
mirror
Ivan, 1987 carrera, as per bentley, does not have it as a separate part, it is riveted probably from the inside of the door, as you say...
I guess I have to strip the inside door cover, find the missing hook and welded back to the broken nut. I wonder if the part can be purchased?
Old 12-01-2018, 04:00 AM
proporsche's Avatar
yup, that is what has happened..When you broke off the mirror the little finger got broken.You have to order new piece.....Yes the nut you see on the bolt is the leftover from 6C
Ivan
proporsche's Avatar
on that 12 every 911 including yours has this bracket riveted and yes it can be purchased...
Personally i do not know bentley book.I found it funny Bentley book on Porsche repairs;-)
Old 12-01-2018, 04:03 AM
Show us some pictures........
David,
Post some pictures of the whole flag mirror. The locking hook could be broken and partially remaining with the assembly. Thanks.
Tony
Old 12-01-2018, 06:12 AM
proporsche's Avatar
all you have to do is buy the little finger and reinstall the mirror.
here is your part number for 6C
911 731 263 00
Ivan
Old 12-01-2018, 07:42 AM
Recently came across this video that has a good description and images of the mirror assembly. https://youtu.be/GeCv1uyYuXQ
Old 12-01-2018, 10:44 AM
side mirror
Thank you all for helping!
parts ordered.
Old 12-01-2018, 02:35 PM
famoroso's Avatar
Cutting the wiring harnesses as opposed to de-pinning the electrical connectors?!?! So cringeworthy. Makes me want to get a rope and string 'em up!
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 02-18-2019, 04:01 AM
Targa_PB_78_SC
mike sampsel's Avatar
Sorry about the troubles you’ve seen with your flag mirror. I noticed mine flapping some in driving at highway speed. I confirmed the whole assembly is a bit loose. This thread helps as I can likely remedy this by tightening the Allen bolt (I.E. #14 into 6c thanks for Ivan’s clarification). I plan to update this if successful.
Tightened it just now, test drive later. It’s a 4 mm Allen wrench.
Old 02-18-2019, 06:05 AM
