IAN IAN is offline
Alternator Ground strap, can I re-use it?
My alternator ground strap is a bit beat up, and I'm wondering if I should re-use it or replace it??
Will it make a difference??
Do these wear out??
thanks
Old 03-10-2003, 11:00 AM
Friend of Warren
When in doubt, replace.
Kurt V
Old 03-10-2003, 11:01 AM
Bad grounds can cause a plethora of electrical problems. Replace it.
Old 03-10-2003, 11:08 AM
Senior Member
Zendalar's Avatar
Costs 3$ at local gas station (in case they have anything else than gas)
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 03-10-2003, 11:09 AM
Cool
a proper sized strap is better than wire for grounds.. most marine parts suppliers have small straps.. and solder the lugs w/proper solder, or get a new dealer part.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-10-2003, 11:25 AM
