If you want to zero the odo, do it. It's a nice mental thing every time you drive it.
Old 12-07-2018, 07:53 PM
Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by tirwin View Post
Herr Ruf clearly stated their cars have their own VINs issued by RUF. I found an article that says that Singers keep their original VIN and odometer reading. My only point was I could only imagine resetting the odometer in an unusual situation, like you took one car and totally transformed it into something else. In that case you could argue that it is no longer what it once was and therefore has little relevance. But it would have to be some extreme, uncommon example.
The odometer is really tied to a chassis. Many people do engine swaps and I don’t think I’ve ever heard of someone resetting the odometer.
Bottom line, I think resetting the odometer, barring some unusal corner cases, is probably just inviting future trouble.
Yes sir, I completely agree. I know Ruf can do their own VINs but I think that's limited to a new chassis and not a CTR or BTR build on your own car is all I was saying.
So if your Porsche VIN starts with W09, you've got something pretty special...
Kevin
Old 12-07-2018, 09:12 PM
El Duderino
tirwin's Avatar
On a side note, when I was a RRVI I saw a company (the name escapes me) that is making carbon fiber chassis. I was wondering if Singer will eventually have to go this route — ie, not basing on existing chassis w/ VIN. I guess if an individual bought a brand new tub it wouldn’t be any different than a kit car. I’ve never really thought about how VINs are issued in those cases.
Anyway, sorry for the diversion.
I see no benefit of resetting the odometer and only negatives. What problem does it solve other than OCD?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-08-2018, 05:20 AM
DLK DLK is offline
I bought a 3.2 targa and imported it from the US to Europe. I just bought a used KM/H odometer and had it rebuild, I also had the miles on the original Odometer calculated to kilometers put on the new KM/H speedo.
I have kept the original speedo with the miles on it. I have documented the change and if I ever sell the car I can show that the kilometers that are showing on the odometer that is fitted to the car are correct.
In holland we have a register that records the kilometers on a car. If I would change it when I do a complete restoration the register will read that the total kilometers on the car are incorrect.
Old 12-08-2018, 06:05 AM
Revs
What does "Title reads mileage exempt" mean? I just saw this on a Barrett Jackson 1979 930 coming up for auction in Scottsdale.
Old 12-08-2018, 10:46 AM
Rescuer of old cars
Arne2's Avatar
Depends on which state issued the title. In Oregon, odometer readings are not required once a car get to a certain age (which I can't recall). At that point, new titles are shown with "mileage exempt". I imagine other states are similar.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-08-2018, 11:04 AM
Yep, same with Washington although, I’m not sure what the cut off date is either.
I’m with the majority here as well. Don’t reset the odometer. Leave that for douche bag used car salesmen.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-08-2018, 12:19 PM
If you reset...you become worst than the rest.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-08-2018, 12:44 PM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I would not zero it out. You can get a used KPH speedo and send it out to have the milage match. The speedo is probably inaccurate because your tire size has changed. Either a bit lower profile, worn or just slightly less circumference then what came with the car.
Chris
Old 12-13-2018, 12:05 PM
It’s your 40 year old car, not an ex-taxi being passed off as a an old ladies Sunday driver. If you want to replace and start at zero, go right ahead.
Everyone goes on like every 40+ year old 911 has a pristine mileage record. Cars have speedo swaps, get imported and exported, break odometers for a while and who knows what else.
Anyone believing a 911 mileage record without super-detailed documentation to prove it is kidding themselves that it is accurate. My car has details service record back to year 1, the title doesn’t match the mileage and there is a receipt for speedo repair. All freely told by the seller. I don’t care, and neither should anyone who is not buying a documented special edition in factory condition.
Old 12-13-2018, 06:33 PM
Yah. My car has well over 250,000 miles on the chassis, and it's worn multiple speedos since I bought it. It'll eventually get a rebuilt instrument showing total mileage.
To the OP;
1) check your tire sizes as suggested. And the speedo part #; irc, at least some years had different speedos for 15" or 16" wheels - so if either were swapped at some point, might not be helping. Also bear in mind the requirements for speedo readings in force when the car was built (usually allowed to be up to +10%, -0%).
2) Why not use a euro KPH-only - or the later 3.2 instrument marked with both MPH/KPH? I'd keep the original instrument.
If the discrepancy/optimism still annoys you (used to drive me crazy, so I sympathize), google "speedo correction yellow dog" ; tiny box that intercepts/corrects the speedo input for electrical speedos; you can install in the dash in about 10 minutes without cutting any factory wiring, just some spade connectors and a piggy-back or two.
I've had one for years. Allows you to correct the speedo to dead-nuts accurate - even with wheel/tire choices that didn't exist when the car was built.
'77 S with '78 930 power and a few other things.
Old 12-23-2018, 12:03 PM
I would purchase a new/old odometer in kph and zero this keep the old speedo and document it in the history file
Old 12-24-2018, 04:17 PM
