915 input shaft seal, how many are they?
Sorry for the stupid question, but how many seals supposed yo be in the input shaft support of a late 915? My transmission came with one seal snd one O ring, but the gasket kit came with two seals and a O ring, and I found one pic by searching google that shows two seals inside the support cone, am I missing something here?
One in the guide sleeve and an o-ring between it and the case, but what year?
As John said one seal inside and one o ring on the outside of the guide tube..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks John and Ivan!
Under the radar
To answer your question. The older 915 transmissions had a non removable guide sleeve. Those transmissions used a different size input shaft seal and the transmission had to be completely disassembled in order to replace it. Thus two different seals in the kit.
