Replace Interior Rearview mirror
Does anyone know how to take off the rearview mirror. My day/night lever is broken. I have an '87 Carrera.
Old 09-30-2015, 02:39 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It is probably not broken, just dislodged. Stick a screw driver up the open and pop it back in.
If the lever itself is broken then it is toast.
If do not have it, get the $4-6 pick tool set of 4 from FLAPS or HB and use the straight pin tool to stick up the bracket to release the tin lock. then it will slip out. You to keep at it until it catches then if you are going to reuse the mirror make sure the tin is back in shape for a tight fit.
'85 Carrera Targa
PCA/POC
Old 09-30-2015, 03:23 PM
Fixer's Avatar
Use a rear view mirror removal tool and be very careful. This is an easy way to crack your windshield.
here is an example of the tool pros use: Inside Rearview Mirror Removal Tool
Matt Mariani @the_r_institute
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Maxilite classic wheels
Old 09-30-2015, 04:11 PM
DRACO A5OG's Avatar
Make sure the lever is set in place
Use a pick tool to release the locking tin tabs
Slides upward
Closer View
Removed, the tab/s are on the window mount
Break a Leg Brother!
'85 Carrera Targa
PCA/POC
Old 09-30-2015, 05:39 PM
Thanks for your help & photos, Draco & Fixer. Now I have some info to get started on resolving this issue.
Old 10-03-2015, 02:30 PM
DRACO A5OG's Avatar
'85 Carrera Targa
PCA/POC
Old 10-03-2015, 05:15 PM
Fixer's Avatar
I get more stressed doing this than installing the windshield b/c you can crack it so easily.
Again go really slow and i wanted to say use some lubricant, the next time i will.
Good luck,-Matt
Authorized Retailer
FIKSE Wheels
Mod Italian Wheels
Old 10-04-2015, 05:50 AM
911 enthusiast
tmadden2's Avatar
After separating the ball from the socket pretty easily, I couldn’t get them back together with my bare hands. I used a zip tie and a piece of scrap wood to make a long handle for the ball joint piece. I put the glass part face down on a towel and was able to press down on the handle ends to pop the ball into the socket. After the two pieces were back together, I cut the zip tie off the ball joint.
Old 12-07-2018, 07:03 PM
