G50 Noise
Hey everyone,
Well I finally picked up my 89' 930 this weekend and everything is perfect except one strange noise. At low RPM's (below 2000), no matter what gear I am in, a rattling noise comes from what sounds like the tranny. The seller told me it is a common noise with G50 trannies. Has anyone ever heard of this? A PPI was performed and no mention of this noise.
By the way, this is the most incredible car ever.....so happy I finally got my 930!!!
Old 03-09-2003, 05:50 PM
Yup. No big thing
Yup... part 2 Welcome to the club.
david 89 turbocab
Old 03-09-2003, 05:54 PM
Rick Lee's Avatar
Correct - common and nothing to worry about. Best fix is to never be below 5-6k rpms.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 03-09-2003, 07:03 PM
I'm glad it's nothing!!!
Now I just can't wait until the weather gets better so I can actually drive the car!
Once I get a chance I will post some pics.
Old 03-09-2003, 07:06 PM
buttjoint's Avatar
My 89 carrera had a funny noise in low gear when I let the clutch out and I was told that all g50s had these noises. Funny thing happened when I changed the flywheel, clutch, THROWOUT BEARING, g50 upgrade, ring gear, the noise went away. I know now that they dont all make noise,
Old 03-09-2003, 07:24 PM
Nothing abnormal according to what I read. My noise is quiet, but noticable - only under about 2K RPM and only when clutch is engaged (pedal out).
88 911 (Sold)
87 951 (Sold)
Old 03-09-2003, 07:47 PM
Porsche had a tech bulletin on this...they tried a number of things, with a number of service bulletins... until finally ( drum roll please !!!)...
They used fat rubber bands around the shift linkage at the point where the access cover plate resides. Excellence in Engineering !!
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-10-2003, 07:04 AM
So does that mean there is actually a fix for this?
Is it a simple fix or pretty costly?
Thanks for all the feedback
Old 03-10-2003, 07:21 AM
KTL KTL is offline
Schleprock
KTL's Avatar
There's more to the G50 noise than just the rubber o-ring around the shift linkage.
Synthetic gear oil quieted mine a bit, but not a cure-all. The gearbox is just noisy. Low speed gear noise is a common complaint about the early G50 trans.
Here's a copy of what Wil mentioned.
Kevin L
'86 Carrera "Larry"
Old 03-10-2003, 08:42 AM
cicsprog's Avatar
Mine rattles like crazy also. Drives me nuts. My local P-Car Dealer says neither attempts by Porsche to fix this problem did it completely. Can someone give me a $ for this enhancement? I am for anything that will quiet it down.
Old 03-10-2003, 09:43 AM
Jamie Summers's Avatar
Yep, mine does it too. A slight graunching / rattling noise particularly at low revs if you come off the gas. I too was told it was totally normal - quite reassuring to find out that it actually is !
'89 3.2 Coupe
Old 03-10-2003, 09:44 AM
Epster77's Avatar
It is good to hear that there are so many noisey G50's. At red lights it sounds like a loose chain.
Truer words never spoken, Richard.
Jimmy
87 911 Cab
www.pelicanparts.com/gallery/Epster
Old 03-11-2003, 04:50 AM
