should this have caused an Alternator issue?
see picture below, I believe this is the ground wire, you can see the case bolt to the right of the eyelet the nyloc nut is loose
-car was charging normally, never saw any indication of any issue -doing some work so I will reconnect when done, that is the main ground wire correct?
1975 914 1.8l 1979 911SC Targa - In Restoration 1972 Pantera Dune Buggy Dual Port 1835cc 1980 911SC Targa - Driver/Winter Project |
Yes, and it is brown. I am not surprised everything was working fine because it is actuall an extra
Precaution to have that wire, but it does give a solid ground. The case of the alternator is grounded to the car by default right? |
I was assuming the same, waiting for an expert better than me to confirm
When I rebuilt my alternator a few years ago my ground wire was not connected, just like yours. Drove the car for thousands of miles this way with no issues. My alternator was rebuilt "while I was in there" because I was making the fan and housing pretty
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
That is one dirty engine. Yuck.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Definitely connect the ground strap.
The early cars did rely on the contact between fan housing and case to ground the alternator. This would not pass any electrical design review these days. For example, metal electrical cabinet doors have earth straps.
www.classicretrofit.com |
hey that was not the purpose of this post
![]() -JK, yes very messy, usual suspects, triangle of death, rear main, valve covers, will be cleaning all and fixing all leaks, my other post will show the pretty pictures when done!
Good luck with your project.
thanks Glen, zero offense, took it as the fact it is!.... but not for long I want and engine to be proud of
