Need help identifying
Hi
Anyone knows where is this tube connected to. It runs from the back of the engine. 79’sc
Thanks.
Old 12-17-2018, 11:28 AM
Trace it back and see if it connects to the front or rear of the throttle body. It's probably either the hose for the vacuum advance or retard on the distributor. There's a number of small vacuum lines back there. Is it connected to a t-connector on your deceleration valve there? I can't quite make it out in the image you posted.
Old 12-17-2018, 05:28 PM
Gazzerr
It connected to the T connector. It’s one of a two vacuum line from the T.
Old 12-17-2018, 05:55 PM
proporsche's Avatar
here is your answer......
1985 911 with original 502 191 miles...808 198 km
Old 12-18-2018, 01:01 AM
Thank you sir.
Old 12-18-2018, 02:44 AM
Another question.
I have read the threads regarding decel vale deleate. Can you please educate me which lines to disconnect and cap. Thanks.
Old 12-18-2018, 03:13 AM
Sorry for the slow reply. Check this thread. It's the go to for CIS here. Hopefully it will answer your question. I'm not too familiar with the pre 80 CIS.
CIS Troubleshooting for Dummies
Old 12-19-2018, 05:41 PM
