hi Gary, thanks for your input,
i added the 5° static advance to the CDI+ curve to come up with the map above...so this is what i was running before the swap...of course i had sortof a stuck vacuum advance, so maybe i was running 5° more advanced all the time who knows. yep, a lot of ignition maps on this board, but bit hesitant to just copy those and run with it. Don't want to wreck a rebuilt engine. bitz is only fuel, so no ignition. and CDI+ = CDI with little bit programming possible. (simple curve, not a map) parameters are not exactly easy to copy from ms1 to ms2...plenty of different parameters, but my experience tells me 13-14 AFR = happy engine...but that was with an innovate LC1 which i don't trust at all... and yep, VE table is nowhere, haven't really started tuning yet. still studying about all the different parameters in MS2 extra. cheers, Jan |
Jan
Yes that was my error in forgetting that the Bitz system was fuel only. Upon saying that I would still utilize the Bitz fuel map to start with. It should give you a more stable fuel map and you can adjust from there. Here is an ignition map that I used to set up my system on mega squirt 2. I reduced the numbers by 2degrees as I had a higher compression ratio. http://forums.pelicanparts.com/uploa...1547063845.jpg You could reduce the numbers by 4degrees to feel safer and utilize the highest octane level available just to be safe. Note: I set the timing in the area of idle (around 45kpa) to the same from 700 to 1000. I set up my table to include the 1000 rpm and stopped at your 6400 rpm. You do not need the 8400rpm column unless you intend to rev that high. |
thanks gary,
ran this last night, and more or less the same story. I'm still thinking hardware issue (weak spark) gonna add a ground lead straight to the battery and see if that helps. https://scontent-bru2-1.xx.fbcdn.net...2a&oe=5CD05043 |
mimiced the VE table from my bitz setup, and in neutral it starts and runs sortof as before, revs nicely...but it won't make power...MAP signal is good, all temps are good, WUE is working fine, etc...
the car reacts very sluggish to torque demand...spark feels like blowing out or reducing or something. |
put an extra ground from my main ground point to the engine, also grounded the coilpack base just to be certain, grounded pin 4 of the EDIS unit to signal ground as well (not necessary), and still the same.
I'm far from being knowledgable about this stuff, but it sounds to me like you're saying the engine will rev under no load, but is "bogging down" under load. Accurate? Forgive me if you've already covered this, but when that happens, what is happening to the timing... is it advancing? And can you see what the mixture is doing via your AEM gauge? Best of luck...we all want to see you succeed. John
Hi John,
yes, that is sort of accurate. The engine starts fine, runs fine, revs fine, sounds fine, AFR's are somewhere in a decent range (12-15), MAP reading is good, advance is good, temps are good, WUE is working, etc...all while standing still. It reacts to throttle stabs relatively good, even tho there is no AE yet. The moment i try driving it, it falls on it's face: no power, the engine doesn't really stumble, but there is imbalance, like running on 4 or 5 cylinders, but less pronounced. The car shakes a bit, you feel it in the whole chassis...and of course no real power, nowhere in the rev range. I don't dare going much higher than 3.5k, but there simply is no power and the engine shakes. If is cruise, it almost feels fine. 3k rpm, in third, no issue. almost smooth. that's why i've got this 'weak spark' idea...sparking just fine free-revving, but not sparking very good under load. Mixture looks fine, even under load. As of now, there are a couple of possibilities still in my head: - injector leaking or something...they're 1.5yrs old so maybe not - spark plug cables look cheap to me, and are too short, 1 or 2 cylinders are quite tight. - maybe i already fouled the new plugs? - maybe some setting in MS that is not right. (injector dead time, ignition input capture) - maybe an unused wire needs to be grounded ? ... cheers for thinking along, Jan |
took out one of my KTM 990 COP's to try it on the porsche engine, it's a denso 129700-4571 and it fits quite nicely...that's a route i might take to do away with the spark plug wires and EDIS coilpack...get a 2nd EDIS unit, and go COP.
i had to take a plug out to take the cap off, and it's black (dry black). |
How much work to put your distributor back in and see what difference that makes?
impossible, it's completely broken...adjustment bracket broken off and innards worn...
How are you verifying your spark angle and trigger offset? Are you using the trigger wizard, the "fixed spark angle" setting in timing or setting a value on the table?
There is sometimes some weirdness with changing a spark setting and the requirement of a power restart during the process to make the setting stick. This sounds to me like your timing is off. What worked best for my uS installations is to set the timing table to a fixed value. Then adjust the angle offset so that it matches the table at idle. Then rev the engine and adjust latency so that the timing stays consistent through the rpm band. You willl probably have to add some advance at higher rpms to get the engine to run smooth enough to get a good latency measurement. |
How long is the pulse length (dwell time) to the EDIS coil? Too short and you’ll have a weak spark which will falter under load.
Most 911 engines will run and drive ok with a fixed timing of 20-25 degrees, they will just have a high idle. I’m not suggesting you leave it like this but if you just fix the timing and still have the problem under load then the problem is NOT the timing. |
I would check to make sure the EDIS module is receiving the spark angle word. If nothing is reveived the EDIS module only sends 10 degrees advanced to the spark plugs for a “ limp home mode”
I may be wrong, but I don’t believe you have the ability to adjust dwell with EDIS. At least I have never modified the dwell settings
indeed, in microsquirt, dwell = standard dwell, or fixed duty, and i don't think it changes anything. the EDIS controller sets the dwell.
i verified the timing by setting my timing light dial to 0, setting microsquirt to fixed timing at 0°, perfect, then again at 10°, perfect. (i made marks on the pulley to check with a 'static' timing light...one tooth = 10°) I change over to ignition map, and i see the pulley advance very nicely. i will check today with trigger wizard. will also clean the plugs today, and order a new set (will take a few days). |
took all plugs out, 5 of them dry and black, but one looks brand new! i feared the worst (burnt valves, hole in piston...), but compression looks perfect, so probably a bad plug, bad plug wire, or bad injector...we'll get there.
seriously, somebody slap me, found out that the one injector connector came off somehow, must have happened when changing spark plugs or so...
it's official: i'm stupid. more testing later. |
Hallelujah...we're back! power is back, all seems well. Engine runs beautifully on all 6. smooth smooth smooth, what a relief. Just a stupid little injector connector! Can't believe how little you can feel that when the engine is idling or free revving.
now i can start tuning properly. Already the car feels much more stable than before. |
That’s great, way better to be humbled by a simple problem than to be right about a major one!
very true, heavy beer time now :)
Glad you found the problem. Good luck tuning to your satisfaction.
Great. Have fun tuning...
just did a 1,5 hour autotune run, it runs so much more stable than before. You can feel that the ignition is now solid. Big difference. Power feels great, but haven't really poked very hard. WOT from 2k - 4k rpm feels great, i've been to 5500 a couple of times, not at WOT, sounds and feels good, but i'm going to leave to high rpm/highload tuning to the professional.
still have one issue: lost sync a couple of times during cold start / warmup. First it would not start (2 explosions and stall), then after a couple of tries, I could get it to go at 3k rpm with the hand throttle, but when i back down gently, all of a sudden it loses sync and stalls. It happened around 10 times, and then never again. Drove it for 1,5 hours without the slightest hiccup. MS gives no reason for syncloss...reason = 0. Let's see tomorrow with a new coldstart. |
must have switched cause and effect. Maybe first start yesterday way too lean, that was why it was not catching, and stalling, and causing sync loss.
with a better tuned VE table now, and WUE configured as before with the bitz kit, i had a perfect cold start (0°C here), first keyturn, no sync loss whatsoever, and a perfectly running engine immediately. time to book an appointment at the dynocentre :) |
just triplechecking the valve lash right now with the Kirk tool...all are mm-perfect.
don't think the kirk tool is all that handy though, i mean, good way to set valves very specifically, but you still have the problem of adjusting-screw rotating while locking the locknut, and also, the kirk tool doesn't really grab tight onto the rocker arm...you have to keep it into position with your hands, or it falls off. not 100% fan here. |
did a 1.5 hour autotune run today...the car officially never drove better than this.
it sounds incredible and it feels so much more smooth than with the worn out stock ignition parts. It fires super stable... i am confident now that the engine runs more than good enough to use it daily again until the dynocentre has time for me. https://scontent-bru2-1.xx.fbcdn.net...92&oe=5CEC50CF |
tuned WOT and cruise at the dynocentre this morning,
top-end same as before (from 185 to 187), but torque all across the range went up quite a bit with the ability to tune the ignition now. +10Nm at multiple points in the range. most importantly: she runs well, sounds sweet and healthy, and hasn't skipped a beat. |
Congrats!! Must be nice to have a perfect running 911 :)
Does anyone make a Plug and Play Microsquirt version? Our cars are getting old would love to have a simple solution to CIS :) I see the 3.2 guys get VEMS |
Plug and play is a bit far fetched, but it's not really too difficult once you educate yourself a little bit.
- get some fuel rails (e.g. bitz), fuel lines, fuel pressure regulator - get a microsquirt + EDIS + some crown vic spark wires + map sensor (trigger-wheels, ebay) - get a toothed pulley, vr sensor and distributor blank (goingsuperfast.com e.g.) - get a AEM wideband kit install everything in a day or 3, junk heaps and heaps of old crap in the process. (CISlambda!) buy tunerstudio and log software, and go, run autotune, and go to dyno to smooth everything out. the fuel pump reverse logic is super easy to get over, with a 10€ standard relay, should not hold you back at all once you do all the other stuff. |
and with EFI, it's never plug and play, you really have to get it tuned. But TBH, it's really cheap compared to the full investment you have to do. And a no-brainer, especially because we are running 20.000€ engines if anything goes wrong...there is no way i would do WOT at 6500RPM with just auto tune.
And doing it DIY you learn what's going on. A Bitz kit with Microsquirt would be a cool wishlist :) /dreams |
| All times are GMT -8. The time now is 08:21 PM. |
