Best Exhaust for 75 Carrera 2,7? Closest to origin
Best Exhaust for 75 Carrera 2,7? Closest to original. Great quality? I saw dansk, but anyhting else? Thanks in advance...
Old 12-31-2018, 06:42 AM
Bill Verburg's Avatar
Dansk purchased SSI, these are pretty much exact copies of the early '70s style, true header w/ heat design
This design is very different from what came oe on the '75 unless it''s a true Carrra RS w/ MFI
If you are changing from the usual '75 style to the earlier header design you will also need a muffler and 2 oil lines
Bill Verburg
Old 12-31-2018, 06:53 AM
its just a regular 2.7. Only looking for something that has the original appearance etc to the factory set up - thermals.
Old 12-31-2018, 06:56 AM
Most owners would want to get rid of the thermal exhaust
Is this what you have?
Bill Verburg
Old 12-31-2018, 07:02 AM
Yes. Looking for original as possible
Old 12-31-2018, 07:03 AM
Registered Minimalist
75 911s's Avatar
I have the original 75 exchangers, egr filter, smog pump, brackets, thermals all in great to poor condition. Also the egr valve and bracket. My 75 California 911s is the same engine as the Carrera for that year. Check my for sale ads in my post history you can view it all there.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-31-2018, 07:47 AM
Can you PM me your email? Would like to see pics and discuss condition... Thanks.
Old 12-31-2018, 07:53 AM
gearhead
Why anyone would keep all the smog crap and bake their engine is beyond me. Put it together like it’s a 74. HEs and a muffler.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 12-31-2018, 10:43 AM
Matt,
I thought the same thing when I first saw this. Two possibilities come to mind:
1.) Concours restoration (even if it is a mid-year)
2.) States emission laws require stock exhaust
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-31-2018, 11:25 AM
gearhead
Originally Posted by Walter_Middie View Post
Matt,
Do any states still test a 75? CA doesn’t. CO and states who mirror CA don’t. Is there anywhere east that is stricter?
A concours resto would make sense but then you’re looking for NOS or like new takeoffs. Also I bet a lot of concours judges would not know that 74 and 75 were different.
I thought through both points before I made my comment.
1974 914 Bumble Bee
2009 Outback XT
Old 12-31-2018, 11:51 AM
I agree with Matt, a cooked engine trumps originality. A set of Dansk SSI’s and rear factory muffler will wake it up and take loads of heat off the delicate parts.
Old 12-31-2018, 01:51 PM
Matt,
Concours restoration .
Old 12-31-2018, 01:58 PM
Ditch the 5 blade fan too
Old 12-31-2018, 01:59 PM
I did.
However id like one to have....
Old 12-31-2018, 02:00 PM
I have date stamped 75 manifolds and 5 blade fan for sale also
Old 12-31-2018, 03:37 PM
disband
juanbenae's Avatar
i agree with both of matt's points above regarding emissions and effective motor health with the actual TR 75 exhaust. i would expect any concurs judge would recognize the short comings of the original exhaust and not ding you too terribly for a set of heat exchangers like ssi's.
maybe look for an original set that's clean enough to look good, but not look brand new. ssi's get some color to the collector and other exposed portions of the actual header that would aid in a "period correct" look. look in the classifieds for a set. it may take a while so if you are in a hurry i guess im no help.
with the nature of the SSI's it would remain consistent with the TR two out look allowing a dansk banana 2in/1out s original. no matter how you slice it a 75 being smog exempt in CA & CO who are the strictest agencies it seems counterproductive to install thermal reactors even if NOS.
happy new year
Old 12-31-2018, 05:00 PM
wayner's Avatar
It was posted on this board at different times that SSI are deemed acceptable even at a concourse level
I couldn’t find the threads but does anyone remember that or have any insight?
SOLD - 914 wide body hot rod
Old 01-02-2019, 02:08 AM
Id be interested. PM me.
Old 01-02-2019, 06:11 AM
