Administrator
Can anyone shed light on these cams specs?
This was referred to me as a Solex grind or a "104/102," but the specs are different than Solex and I have no idea what 104/102 means. Anyone know what this cam is or how it should perform in a 2.2L engine w/ 9.8:1 Mahle 911S p/c's?
That’s a nice cam for the application specs you mentioned. Should be good to around 7000rpm with peak power made a bit below that depending on your port sizes. Has a bit less duration than a standard S cam.
No physical quantity completely explains its own existence Last edited by lvporschepilot; 12-28-2018 at 05:49 PM.. |
Administrator
Thanks -- anyone else have experience with this cam, or can recommend cam timing spec?
Chain fence eating turbo
It'll be hp peaky with the tight lobe separation angle (102 you were referring to)
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
gearhead
It was Web’s own version of a Solex cam. I think some people have called it a mod-Solex. It’s intended for 2.0-2.2l engines and isn’t quite as aggressive as an S cam. I sold a ton of these for high compression street rods when I was at Carquip. It won’t make any power over 7k, as was mentioned.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 Last edited by Matt Monson; 01-02-2019 at 01:43 PM.. |
