-   -   Engine Drop/Stand Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1017517-engine-drop-stand-question.html)
piscator 01-07-2019 05:30 PM
I'm about to do my first engine drop and unclear on what I need for a stand.
I'm planning to buy the (five arm) engine stand yoke but do I need the engine stand base? Or do the commonly found rolling engine stands already have a place to "plug in" the shaft of the yoke?
Alternately, I have a heavy workbench that I could mount the engine stand base to. Doesn't seem as convenient as the rolling stand. Thoughts?
I'd appreciate any recommendations on yoke/stand setups.
Thanks,
Robert
juanbenae 01-07-2019 05:54 PM
the hard part is getting it from the dolly up to the stand.
75 911s 01-07-2019 07:37 PM
The common rolling engine stands will fit the 5 arm yoke. Because of the wide weight distribution of a flat six, I think the two leg engine stands are more stable. I ordered mine from Costco. Nice stand and can be broken down and stored fairly easily. There is a bench mount for the yoke. Obviously your bench has to withstand 400lbs or more.
piscator 01-07-2019 09:08 PM
Juanbenae, thanks, I bought an ATV jack to lower the engine; not sure if it will be high enough to get the engine onto a stand. I have a chain fall and a strong beam in the garage, as well.
75 911s, Thanks, that's what I needn't to know. My bench is substantial, but I'd prefer using a stand. I've had good luck with Sears, but never shopped at COSTCO,
Robert
Dpmulvan 01-08-2019 03:47 AM
Harbour freight stand works fine, make sure you get the heavier one for motor, or buy one off craigslist.
fred cook 01-08-2019 04:56 AM
Things you need........
You will need the rolling base, the 5 arm yoke and having a hydraulic engine hoist will make things a lot easier! In the long run, you will find lots of uses for the hoist!
I use a Sears ATV jack with a 2'x2' piece of 3/4" plywood to go under the engine for lowering and lifting. Works great and is much more steady than a floor jack. You will find that having a floor jack will be helpful when reinstalling the engine to help get the right angle on the engine/transaxle unit.
Also, when removing or installing an engine, I raise the car up just enough to get underneath to loosen or remove everything. Then, once the engine is on the ATV jack, I I raise the car enough to roll the engine out and then lower the car back down to a more solid level (safety first!). Going back in is just the reverse, raise car up high, roll under the engine/tranny, lower the car to a safe working height and then install the engine. Good luck!
cmcfaul 01-08-2019 05:05 AM
Ask you local PCA folks. For sure someone will lend you the proper stand. Getting the engine onto the stand will require some strong backs or a comealong to the beam you mentioned.
Have fun!
Chris
Mike Andrew 01-08-2019 05:15 AM
+ 1 on the Harbor Freight stand. Inexpensive and worked very well for me. You can rotate the engine for access to all sorts of things and it is very stable. It also breaks down nicely when you are done with this project.
Where are you? Perhaps you could borrow one from one of us and save the expense of buying a tool that you will likely only use once or twice.
Targa Me 01-08-2019 05:48 AM
I used a chain hoist to raise the engine from the AV jack to the engine stand.
I also added 4x6 board to cross over 5 of the garage joists to even out the weight of the engine.
piscator 01-08-2019 05:57 AM
Thank-you gentlemen! My project is underway!
DP and Mike: I think you mean the Harbor Freight stand like the one in the photo below? I may be able to borrow one, but they’re not tremendously expensive. I think the five arm yoke is expensive, for what it is. Haven’t seen one for less than $300.
CM, I’m not a PCA member but I have a friend who is. The back’s not as strong as it used to be. That’s why I own a ‘come-along! :-)
Fred, Thanks for your excellent advice on raising and lowering. I will follow it! I think it was one of your prior posts that encouraged me to get the Sears ATV stand. It seems to be good quality. I’ve been well served by Sear’s Craftsman products. I wonder if they have a good engine stand.
I also appreciate your recommendation on an engine hoist. I think you mean something like the picture below, yes? I take it the ATV jack doesn’t work for getting the engine onto the stand? Do you think the hoist is easier than using my come-along attached to a strong beam?
At my old shop, I had an industrial engine hoist that we used for a lot of things. Somehow it rolled away, all on it’s own! Funny how that can happen.
Robert
http://forums.pelicanparts.com/uploa...1546959345.jpg
piscator 01-08-2019 05:59 AM
TargaMe, thanks! I have a heavy laminated beam in my shop that's supported by steel posts. It's pretty strong!
Robert
boyt911sc 01-08-2019 06:45 AM
Nice to have the right tools and equipment.......
Robert
Robert,
Invest on these necessary tools and equipment for your engine rebuild. If you own these equipment, you have the pleasure and luxury of doing the project at your own pace. Specially if you are doing an engine rebuild for the first time.
The HF engine stand is sufficient to handle a 911. Get the engine stand similar to the one you posted with an open access to the bottom front. I have 3 HF and 1 Manley engine stands and 4 yokes. The Manley engine stand is remarkable and robust but costs as much as the 3 HF stands combine. A portable engine hoist is great to have for moving the 911 engine on or off the engine stand. I also need an engine hoist to install the motor in my engine test stand for the start up.
http://forums.pelicanparts.com/uploa...1546960406.jpg
This is my 25-old and reliable engine test stand made from scrap metals including a traffic sign post as the main frame.
http://forums.pelicanparts.com/uploa...1546960709.jpg
This is when you need a portable engine hoist to get the assembled motor in an engine test stand for the start up. The Manley engine stand was eventually used but the HF engine stand was fine for this application.
Pazuzu 01-08-2019 06:57 AM
Be aware that the Porsche yoke is slightly larger in diameter than some "American" engine mounts. I've seen more than one stand that did not take it, it was maybe 1mm too big in diameter. Some time with a drill and grinding disk will fix that, but it's worth doing some careful measurements first. I have a Powerbuilt 647514 which does work fine.
piscator 01-08-2019 09:26 AM
Mike, Duly noted. Thanks very much!
Boyt, Great advice and wonderful pictures! I’ll make sure to get the wheeled stand that’s open in the front. An engine hoist shouldn’t set me back too much.
Is the aftermarket 5 arm yoke o.k.? Or do I need to spring for OEM?
Damon in STL 01-08-2019 10:05 AM
Where are the best pick points on the engine when hoisting/inserting into the stand?
yelcab1 01-08-2019 12:24 PM
I have used both a engine cherry picker, and a 4 post lift to hoist the 911 engine and yoke on to the stand. The places to attach the chain are, 1) around the mounted yoke, and 2) one of the mounting bolts on the engine carrier. Use some towels where the chain rubs on anything you don't want damage.
911 Rod 01-08-2019 12:40 PM
Don't use a come along to lift your engine. Use a block and tackle.
Bob Kontak 01-08-2019 01:24 PM
One ton manual chain hoist at the freight is $60.
With open rafters, it's a good choice.
Span several rafters with a fatty as noted. A 4x4 would work as well.
Sboxin 01-08-2019 02:08 PM
Thanks,
Robert
We used the adapter ring (half ring) and HF engine stand - some added pipe, bolts and nuts - worked fine for a 964 disassembly - a lot less expensive than the yoke you are thinking of buying - ring from Pelican "Engine Stand Adapter Ring for Porsche and VW air-cooled engines" - enjoy your project . . .
Regards,
http://forums.pelicanparts.com/uploa...1546988701.jpg
http://forums.pelicanparts.com/uploa...1546988825.jpg
lyonsfin 01-08-2019 02:58 PM
With the flywheel off, the adapter ring worked fine for me. I think the ring was under $100 and I found a used engine stand like the HF one pictured for $40 on craigslist
911T70 01-09-2019 03:28 AM
This is how I do it - works well for me... and cinder blocks are cheap!
https://www.youtube.com/watch?v=SxAcLwzAJ3w
piscator 01-09-2019 03:37 AM
911T70, That was a very impressive film! Worth several thousand words! Thanks so much.
fred cook 01-09-2019 04:17 AM
When I was getting ready to rebuild my engine, I kept on checking the classifieds for Porsche tools. Eventually, I found an ad where an engine had been rebuilt and the builder was getting rid of all the Porsche specific engine tools including the 5 leg yoke, cam tools, etc. I was able to buy the whole set for the price of the yoke! It never hurts to keep your eyes open for deals!
Dpmulvan 01-09-2019 05:04 AM
Keep in mind the harbour freight cherry picker(hoist) has legs that are not wide enough to straddle the 911 motor. I cut mine up and built a rotisserie, found a $99 coupon and bought another for the front.
mike sampsel 01-10-2019 01:49 PM
yes 911T70! very great and informative video on UTUBE, maybe I will drop my engine some day!
911T70 01-11-2019 04:01 AM
Glad you enjoyed it! I made it to document the procedure because I had to re-figure out the steps every winter - added the music for fun.
Drop your engine if you get the opportunity. It's intimidating at first but not that hard. I'm very happy I learned to drop mine - my car wouldn't be running as well as it is if I hadn't; makes routine maintenance/repair so much easier and it's a bonding experience with these amazing machines!
Here it is going back in:
https://www.youtube.com/watch?v=eAZm6SyTS1U
'78 SC 01-11-2019 05:39 AM
transferring engine to stand
Like many of you, I work solo and need a safe, dependable way to transfer the motor to/from the engine stand. After I figured out that supporting the motor with stacks of scrap lumber did not fit those criteria, I started using a chain hoist. Initially I hung it from the ceiling joists, but needed a way to move the engine to the shop side of the garage (there's a step between shop and parking areas) so I made this trolley:
http://forums.pelicanparts.com/uploa...1547216547.jpg
The trolley (part that rolls) and supports are from McMaster. The Unistrut is from the local home improvement store. Trolley is rated for 600 lbs.
Here's transferring between the engine stand and hydraulic lift table. Note the step: the trolley lets me move the engine past the step and put the engine stand on the upper level:
http://forums.pelicanparts.com/uploa...1547216702.jpg
piscator 01-11-2019 06:20 AM
DPMulvan,
You raise a good point concerning the width of the cherry-picker legs! I'm thinking that the legs would need to be wide enough to slip around the ATV lift I'm using to drop the engine. The engine is wider than the lift, but I'll have to do some measuring.
On the other hand, if you can secure the cherry-picker from sliding, wouldn't the engine just swing into place as it's lifted? Or slide into place using some plywood over the cherry-pickers legs?
Just pondering...
Thanks again!
Robert
onevoice 01-11-2019 07:05 AM
There is more than one way to skin a cat.
I used my welding table on wheels to support the engine as I undid all the connections and lifted the car up using a four post lift. Exhaust removed.
Completely disassembled the engine, then decided I liked working at the higher height of the table instead of the height of my engine stand, so I made a couple of wood stands in the shape of the crankcase in the upright position and 90 degrees rotated. Did all the work assembling on the two wood stands on the table. It was really handy to have a flat surface all around the engine. There was plenty of room to work, and very sturdy. If I did it again, I might make some slick aluminum stands to replace my wood ones, but I would still do it on the table.
The only reason I could see to have the engine upside down is for the exhaust, and I did that in the car.
wildcat077 01-11-2019 07:49 AM
I posted in an engine removal thread a few years ago where i lifted the rear of the car with an engine hoist using the engine support bolts and a home made sling with chains ... made a wooden dolly to drop the engine on and rolled it out from under the car.
While searching i saw some pretty scary set ups whereas some really intrepid mechanics had their car jacked up on a pile of wooden blocks.
There are many engine removal threads on the forum , you just need to find the right one !
Strygaldwir 01-11-2019 11:44 AM
Piscator (is that fisherman as I recall all that wasted time learning Latin);
The problem is that you have to stretch a cable from the cherry picker to the engine be case the legs won't fit under the engine. When you start jacking it just pulls the stands rear legs up.
I am pondering a solution to this as I contemplate how to get my engine onto my new engine test stand!:confused:
piscator 01-11-2019 11:55 AM
Strygaldwir,
Piscator is the name of Sir Isaac Walton's sidekick in "The Complete Angler," but yes, also "fisherman" in Latin. I'm more familiar with the former than the latter! ;-)
I see what you're saying about the cherry-picker's rear legs. I think my best bet is to hoist it on the laminated beam in my shop, it's plenty strong.
When I went to Harbor Freight today, I could see the cherry-picker wasn't going to work. BTW: HB's having a three day sale. I got a $30 discount on the 1ton engine stand and 6ton jackstands for $37 ($7 off).!!
Thanks for your post!
Robert
aka: piscator
Neilk 01-12-2019 08:27 AM
I used a come-along the first time to get my engine onto my HF engine stand... I realized when I was done that a come-along works great going up (tightening), but not down, so I bought a chain hoist from HF. It's much more robust and less risky.
piscator 01-14-2019 10:52 AM
911T70,
I'm copying your skid design for my engine drop; which is going to happen in about 15 minutes, as soon as I finish my pizza lunch! Everything is disconnected and all I have to do is 'lower away!' Your removal film has been a big help!
Robert
911T70 01-15-2019 02:50 AM
Originally Posted by piscator (Post 10316383)
911T70,
Robert
Good luck - let us know how it went!
boyt911sc 01-15-2019 06:01 AM
HF engine hoist.........
Originally Posted by piscator (Post 10312954)
DPMulvan,
Just pondering...
Thanks again!
Robert
Robert,
The HF engine hoist legs opening could be overcome by a simple contraption. I have used this hoist for many years moving engines from engine stand to engine test stand much wider than the engine width. Like someone mentioned earlier, there are many ways to skin a cat. Or think outside the box.
An ATV or hydraulic table is nice to have for your engine drop and could get away without an engine hoist. But having an engine hoist is an advantage and more efficient. What ever you decide to do, stay safe.
Tony
piscator 01-15-2019 06:21 AM
Tony,
What box????? There's a box?? :-)
"Like someone mentioned earlier, there are many ways to skin a cat. Or think outside the box.
Thanks Michel!
Robert
piscator 01-15-2019 01:53 PM
Engine's out! Thanks to everyone for the help and support!!
http://forums.pelicanparts.com/uploa...1547592688.JPG
911T70 01-16-2019 03:01 AM
Congratulations! A great feeling of accomplishment, isn't it!?
911 Rod 01-16-2019 05:13 AM
Nice!
It gets a lot easier each time you do it.
