Targa_PB_78_SC
Fresh air fan control removal
My fresh air fan works in switch positions I and II, but not III (but Position I and the fan light are a bit flakey at position I).
Suspecting some dust or fuzz is creating poor contact poor for the switch. Bentley gives no instruction on removal of the control panel with the three levers. Anyone know of good instructions? Perhaps there is a way to spray contact cleaner at the switch in situ? Anyone have a picture of the back side of the levers/switch? Desperate to break something
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fan.
the light harnesses. Removing the ash tray & radio will give you visibility. Some type of alcohol spray cleaner might help. As a precaution, turn off the dash lights prior to cleaning. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Not my favorite job, to say the least. You can try getting your fingers up over the sliding electrical contacts and pressing down as you work the outer knob back and forth in an attempt tp scrub the contact surfaces. Works sometimes.
Targa_PB_78_SC
Thanks for the ideas guys. Appreciate them
Yeh what John said no fun removing these to work, here's a pic of contacts the photo shows position 2 middle
Few more
Targa_PB_78_SC
Dpmulvan,
Fantastic photos just what I needed to help me determine what to do. Thank you so much! |
Not one of their better design elements, to remove you have to disconnect cables that run up under the left side (drivers side) and then through the firewall.. If you can get a hose or straw in there you can spray it with deoxit good stuff works miracles. You can buy it on amazon used to clean pots and other audio and electronic parts.
This job= 3 curse words 2 beers.
Not to mention future lower back problems from the contortions to get into a position to see and reach in there. Plan on a couple of scratched up fingers as well. I used a plastic-safe electrical contact cleaner and lubricant by CRC called 2-26. It's safe for use on all electrical parts. Google it for sources.
Don Rocklin, CA -85 Carrera |
Pull the radio and those switch contacts are right there and are easily accessible. In my case of switch goodness, a previous careless radio installer had slightly bent down the curved contact plate causing problems. Simple bend and test, clean contacts and I was back in business.
Targa_PB_78_SC
Was good exercise bending around from seat to seat and reaching up. Hit it with some contact cleaner and tried the move switch back and forth while holding contacts down. The high speed kicks in but is intermittent.
Went to grab my DeoxIT which I had ordered a year ago: Discovered it’s not the one recommended for metal to metal ![]() ![]() ![]() Looking for the right one on amazon soon. Thanks again for all the advice. |
Side topic question: These early fan controls (I have a 71), are there lights on this panel?
Do they operate with the fan? Or do they operate with the dash lights? My controls work fine, but no lights. Thanks |
What do you mean with 71? I see in your garage you have a 78SC.
In this case yes, while the blower starts you should see the fan enlightened. Not other lights
Paolo from Alps 1980 911 Targa SC 3.0 - Silver metallic 1980 Ducati Pantah 500 - Red 1989 Yamaha 500 "Tracker"
I'm referring to the 71... Thanks. Sorry for the distraction, useful if I need to remove this thing to get to lights (that may or may not exist!) |
Targa_PB_78_SC
My light (fan emblem to the far right of the panel) illuminates with the fan slide at center to right.
Pretty sure it’s the larger metal connector which grounds my fan light. It doe not illuminate with the lights. The rest of the stuff, FAN and max def and def off light up with light switch. |
Targa_PB_78_SC
So I sprayed some contact cleaner inside (after radio removal). And slid things around.
Seemed to help but not fixed yet. Tomorrow I planned on hitting it with the cleaner/lube pictured. However today when I pushed the control all the way to the right, high speed works. It’s s wee bit noisy too. Anyway thanks again all |
Man those pics are great! What electromechanical “Rube Goldberg” machines our pre 90 air cooled 911s are!
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Senior Member
Yay!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Targa_PB_78_SC
Superman,
In addition to cleaning the contacts, I’d consider some contact lube/cleaner too. Like DeoxIT F5 or D6. |
