H4 re-assembly help
Hi, I'm in the process of refurbishing a set of used H4 headlights. I understand how the two adjustment screws fit into the reflector, but I'm assuming there's a third fixed screw needed somewhere, and I can't find any images of this, and they were missing from my headlights. Can anyone send any pictures or a description of this screw or let me know if I've got this wrong?
Thanks John |
H-4's
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
Thanks. The image above isn't detailed enough to show the part I'm looking for. I found this image that shows three bungs through the reflector.
Two of them are for the adjuster tabs, but my question is if there is something that fits into the third bung?
Going by memory, one of those three is fixed between a tab from the outer ring. It is the pivot point for the other two axis of adjustment.
1978 SC Targa |
You can sortof see it in this photo -
1978 SC Targa |
Perfect thanks. That should be easy to sort out
John |
Here’s what I have in my garage.
Let me know if you want pictures of a certain area . ![]() ![]()
I have them back together and on on my car now. Thanks for the offer though, l appreciate all the help.
