1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
window crank just failed
The pivot pin on my manual windows just broke. Is there a replacement available or do I have to replace the whole regulator?
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 03-14-2003, 07:17 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
2 choices....
Make a new piece (I suggest stialess steel)
Or..buy a new or used unit.
Bob
Bob Hutson
Old 03-14-2003, 08:27 PM
Replacement pivot pins are available from several sources (Pelican, I suspect as well). Select the pin that has the slot in the right configuration. Does somebody have pictures of the pin options? (check the Pelican catalog). Pick the one that matches yours. Left and right side door windows may be different.
The factory pins are lead, potmetal or somesuch. The replacement pins are made of steel. It's not too difficult to replace. See if Wayne has it in his 101 book.
You're fortunate they lasted this long.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 03-14-2003, 08:54 PM
Cool
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-14-2003, 09:36 PM
1.367m later
KevinP73's Avatar
Thanks Guys....Hey Ron where is that image from? Someones catalog or??
Old 03-14-2003, 10:42 PM
Cool
Hey Kevin... you gotta eyeball and measure your broken pin.. to my understanding there is no rhyme or reason to what years had the various pins.. but there may be.. I'm not as smart as I look.. then call Wayne at Pelican Parts.. then problem solved......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-15-2003, 06:34 AM
