Fresh air blower harness socket part #
Hi, anyone got a part # (and ideally, another source if our host doesn't carry it) for the socket on the end of the harness to the fresh air blower/squirrel cage in the frunk?
Mine's mostly disappeared. Same family as the power seats or the engine bay plug/socket, but a 4-pin variant, can't seem to find it in PET...
'77 S with '78 930 power and a few other things.
Old 01-28-2019, 02:55 PM
ROW '78 911 Targa
timmy2's Avatar
The Only “kit” available to get the correct 4 terminal housing and cover (with just 3 new terminals included in the kit) is sold as for the fuel tank sender. Not inexpensive either....
(just reuse one of the terminals you take out of the old connector).
Part number is 901 612 891 00
Google it for pics.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-28-2019, 09:56 PM
The 86 and 89 Carrera PETs have electrical part connectors listed. Sorry but I'm not sure of your connector style.
Old 01-28-2019, 10:20 PM
ROW '78 911 Targa
timmy2's Avatar
Here is a pic for you.
https://www.pelicanparts.com/More_Info/90161289101.htm?pn=901-612-891-01-OEM
Dennis
Old 01-28-2019, 10:48 PM
Google it for pics.
Awesome, thanks!
I noticed in 2006 that the top cover had evaporated, so I wrapped it up in parcel tape to hold the connectors in/"protect" the naked terminals.
Remembered that I never touched it again. Figure it's past time to do it right...
Ahh, the penny drops - thank you! I knew I'd seen that somewhere before, but went all the way through the older PET looking for the connectors page and just. couldn't. find. one....
Old 01-29-2019, 10:15 AM
I'm in the same boat. Glad you posted this and found a source for the plug!
But, here's the problem - With or without the replacement socket we need to figure out how the wires should be plugged back in.
White w/Green - Speed I
White w/Yellow - Speed II
White - Speed III
Black - Power from fuse #12
The blower unfortunately is not very clearly marked. One pin is marked 8005 another 8006 and a K between the other two. None of these markings are found on the klemmenbezeichnungen DIN legend...
1978 SC Targa
Old 02-01-2019, 03:47 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
color codes.
White - Speed III
I have the factory manual.
Can you please provide the wire colors?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-01-2019, 04:17 PM
Gerry
Thanks Gerry!
White - Speed III
I pulled the blower and with a flashlight I can see the inside of the plug. There are two resistive coils and only two wires going to the motor. So, I'm guessing you have power and three grounds coming from the dash switch. Two of the grounds go through resistive coils to slow down the fan.
I could not see enough detail to figure out what pins are connected to what...
1978 SC Targa
Old 02-01-2019, 05:03 PM
ROW '78 911 Targa
timmy2's Avatar
Wires come in from bottom. Looking into connector with top cover removed.
I do a lot of these as they are often messed up on the dash harness.
Dennis
Old 02-01-2019, 10:05 PM
Connector
As per my factory manual.
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-01-2019, 10:20 PM
Dennis & Gerry - you guys rock!
My wires weren't disturbed in the plug (yay, parcel tape!). So I cut it back to see if it would help out - then didn't post as I noted wiring on the '77 is different, not only colors; red with a white stripe where white/yellow above, red with a black ring where it shows white above, and red with a green stripe where white/green above - but also only 3 connectors wired:
So apparently no fused 12V on the black wire in the 4th hole. Yet, the (single) dash lever gives the expected increase in rattling noises - sorry, fan speed - at positions 1, 2, 3.
Presumably the dash control is wired differently on the earlier cars?
Old 02-02-2019, 08:24 AM
ROW '78 911 Targa
timmy2's Avatar
Spuggy
These photos are from my 1977 factory manual.
The first one shows the wiring to the fresh air blower under the cowl.
Based on the colors and number of wires, You apparently have the A/C connector in your photo.
(Next 2 photos of schematics for ‘77 A/C)
Dennis
Old 02-02-2019, 10:10 AM
Agreed! Dennis has gotten me out of quite a few electrical pickles!
1978 SC Targa
Old 02-02-2019, 12:32 PM
I was able to track down a used plug, but the clocking pin and wire entrance is opposite of what I expected.
1978 SC Targa
Old 02-14-2019, 11:20 AM
