86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Diode Location & Access.
Looking for the "Top Secret" location & access
for this diode.
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-13-2019, 09:41 AM
T77911S's Avatar
try the left side under the dash.
it may be in a big/long plastic "connector"
may I ask why.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-13-2019, 10:35 AM
This is the diode from my '78. It is near the right side hood lift shock.
No idea if your '86 is similar.
1978 SC Targa
Old 02-13-2019, 10:41 AM
may I ask why.
The diode you are referring to is the
other diode that is on the light switch
used only on the M/Y 1986.
It is used to turn off the license plate light
when the "standing" lights are on.
As for my post, it would appear that when I turn on
the "standing" lights by placing the turn signal
to the right for the passenger side, the "standing"
light does not activate, but works well for the driver's side.
The system, as I recall, is selective for either
left or right standing lights.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-13-2019, 10:43 AM
Diode.
I'll have a look.
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-13-2019, 10:45 AM
Originally Posted by 86 911 Targa View Post
I'll have a look.
Thanks,
Gerry
Just checked my notes and the diode I referenced is for the door switches/interior lights. Sorry, wrong animal.
1978 SC Targa
Old 02-13-2019, 10:50 AM
Diode.
Still looking, can anyone help?
Thanks,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 07:30 AM
steely's Avatar
Do you think there is a chance it could be part of the harness between the stalk plug and the intermittent control module but under some insulation? (inline or integral to the harness)
I looked and found 2 candidates but they may not be good ones. These were located behind the dash and between the dash and the drivers side frunk hinge. I didn't see yellow wires tho'.
One with red/blk wires appears to be inches away from the rear wiper switch so may be for the rear wiper. The other was wrapped do tightly, and it may just be for the parking Lights.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-14-2019, 06:54 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
if its the one Im thinking of, its wrapped up in the harness behind the wiper motor/fresh air housing..
Marc
Old 02-14-2019, 07:07 PM
Diode.
I'll have another look at the CKT,
and try to find a way to do a front/back ratio
on the diode.
Thanks to all,
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 09:41 PM
steely's Avatar
Aha!
Pic is from post 22 of this thread: wipers not parking no intermittent wipers
Diode with yellow wires right under the intermittent wiper relay.
Dan
Venetian Blue
Old 02-14-2019, 09:45 PM
Diode.
Originally Posted by steely View Post
Aha!
If this is the issue, It's not going to be any fun.................
Thanks again to all.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 10:08 PM
Links.
https://www.youtube.com/watch?v=e2RqkUE5Grw
https://www.youtube.com/watch?v=-lEsj19bdyM
Here are two "Thank you links".
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-14-2019, 10:26 PM
kbruz's Avatar
On the 86. The diode is located under the dash on the left side. It is likely tucked right under the ignition key and light switch. It looks like the picture that is posted.
kb
mercedes GLK350
2009 boxster s
86 targa
Old 02-14-2019, 10:45 PM
T77911S's Avatar
yes, the diode is for the right side and when bad they don't work.
if the left side does not work then take a look at the turn signal contacts.
the diode you have on the diagram is not for the lights, it looks like that one is there to turn on the wipers when you activate the washer pump.
RACE CAR:: sold
Old 02-15-2019, 04:08 AM
I recently had a problem with the “standing” lights on my 89 930. Driver’s side was not working, passenger side worked fine. Starting from the fuse block, traced circuit to the light switch and then to the turn signal switch verifying voltages. Found 12v in all the correct terminals. No diodes in MY89 to worry about though. Concluded the turn signal switch had failed internally, replaced and all is well.
Old 02-15-2019, 06:16 AM
