Need a schooling on HE vs Headers for a 3.2
The 3.2 I recently bought did not come with an exhaust system so I have some decisions to make. I am in SoCal, and the car gets used for touring events so it will see weather (that will be pretty modest still, not freezing etc). Car needs to be livable, does not need to pass SMOG.
I was hoping to get a crash course in if headers make a worthwhile difference, if so which ones? Are there HE that are close to the same power and provide heat / defrost? What sizing for a ‘88 3.2? Thick vs thin flange? Total exhaust newbie here.... Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
UnRegistered User
Good thread (but $$$$).
Bigger "SSI" system
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Registered Minimalist
For a stock 3.2 you can run original SSI HE. There's data that supports it being a good match. I believe your Carrera will have the shorter studs, so thin flange. Simply measure your studs coming out off the exhaust portion of the heads under the car.
Some clearance issues can develop. I think on the right side header, you may have to dent the heat box on the header to clear the chain box. Sometimes you have to make an adjustment to clear the helper spring on the trans as well. That's going to be your best bang for the buck imho. If you go bigger with a stock 3.2 you could actually lose power. If you go aftermarket, there are quality headers like Georges, or cheap chinese headers like QSC. You can get them in any size you need. There are also high end heat exchangers like billy boat and fabspeed. FWIW I live in Vegas, and I still use my heat all the time for those cool morning runs in winter, late fall and early spring.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads Last edited by 75 911s; 03-11-2018 at 08:19 AM.. |
Thanks gentlemen
www.classicretrofit.com |
Interesting!
SSI are only 1 3/8"ID (~35mm)' 1 1/2" OD, this is fine for smaller engines or lower rpm use, they will not flow well enough for full hp at higher rpms. They will enhance torque at lower rpm. The Eisenmann 42mm SSI copies referenced in the thread above are probably the best currently available for a 3.2 or 3.4 Less money would be B&B or Fabspeed 1 5//8" headers, but it's more difficult to put a good muffler on these. 1 3/4" headers are too big for 3.2 W/ a muffled system you don't get the full benefit of tuned headers anyway so another decent choice might be stock 964 w/ 37mm pipes or 993 which are ~42mm. Again these will be more of an issue to get a decent muffler on.
Thanks Bill, very helpful.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
JP/Dansk are making 41 or 42mm OD SSIs, tagged as Under Development in their catalogue.
I think they have been under development for a couple of years at least!
After reading about a million posts, of which about 99% were found to be factually deficient, I ended up ordering a set of http://www.bbexhaust.com/shop/porsche-911-header-with-heat-exchanger-fpor-0401/ with 1 5/8" primaries so I can use a 2 in/1 out Dansk motorsport muffler. I know I will need to use spacers under the exhaust stud nuts since I will continue to use the longer 3.2 exhaust studs. I hope I don't also need to make 20mm spacers to go between the header secondary flanges and the muffler inlet flanges but will if I have to. From the believable sources it appears the standard 3.2 headers work really well if the muffler and cat are replaced with freer flowing units and are really very competitive with the more expensive street exhaust alternatives on any objective measure. If you're interested in sound info on 3.2 street systems, suggest you keep your eye out for posts from Steve Wong, Bill Verburg and scarceller. For example: What can I expect - 3.2 w/exhaust and chip Last edited by Peter M; 03-13-2018 at 02:34 AM.. |
Interesting that they don't tout the compatibility w/ stock 911 2 in mufflers, That has always been the major drawback of the B&B headers.
B&B and Eisenmann - neither use (or offer?) thick flanges. Are they still deemed required on a 3.2 up?
No, thin flange can be used on any 911. You just need to either change the studs to shorter ones(likely necessary anyway) or live w/ the long stud shaft prouder than usual
Thanks - why do thick flanges exist?
Sorry slight OT |
Yes, the BBE site isn't the easiest to navigate and that's why I included a link. I contacted them directly to confirm they were the 1 5/8" primary tube size I wanted. I suspect they have made them for many many years but never promoted them as being suitable for 3.2's because of the flange thickness issue. I've only found one other on this forum who has installed these on a 3.2 using the generic 2 in muffler and this is the reason why I steered away from their normal 3.2 headers as I didn't want to use their propriety mufflers with the odd spaced 3 bolt mounting flange inlets. He didn't have to use adaptors spacers to fit his muffler so I hope I'm the same. I will confirm the wisdom of my purchase when they finally turn up and I can trial fit them. Thanks for your help BTW through your earlier posts on this topic. Last edited by Peter M; 03-13-2018 at 01:22 PM.. |
The Eisenmanns look the perfect solution but they are eye wateringly expensive where I live and I couldn't find any reliable data on hp gains so shied away from them. Last edited by Peter M; 03-13-2018 at 01:24 PM.. |
I think this should be noted as going in 914-6 so exhaust options are limited to stock, mine, and b&b and not sure if anyone else is in the game?
I prefer a 1.625 header sizing for a 3.2 engine and stock is 1.5" Here is a picture of my product.. Just want to make sure correct info is being relayed to the poster.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Interesting. - I see INd Dist are marketing a 45mm option?
https://ind-distribution.com/product?sku=P91130.WT38 |
The Eisenmann both look thin flange from the pics I’ve seen, certainly not same as ssi thick flange
