Tony
ER trailing arm bushing install with arm in the car?
I’ve watched Chuck do this on his YouTube video, without disconnecting the other side of the arm. My question is what trick can I use to get the arm lower on the front end? I hung my 185 lbs off the end and I couldn’t get it clear. Any ideas?
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
I believe you have to remove the lower shock bolt out of the arm. Be careful of the brake lines as you lower the arm.
Tony
Yep of I’ll try that, that’s easy
