Counterclockwise?
New idea on torsion bar foam seal?
I need to replace these as they are shot. They don't work very well with polybronz bushings because the pressure of the grease pushes right past them.
Has anyone come up with anything better? Big ass o ring?
Rod
1986 Carrera
2001 996TT
Old 02-25-2019, 01:12 PM
ninelevenick's Avatar
I used car battery terminal post felt pads. Worked like a treat.
Old 02-25-2019, 02:12 PM
911tracker85's Avatar
hmmm dont recall these on my 78 SC. where do they go? in the process of reassembling my suspension front and rear.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 02-26-2019, 06:32 AM
piscator's Avatar
Didn't find these on my '79 either. What do they do?
Robert
Old 02-26-2019, 06:34 AM
Counterclockwise?
The adjustment caps on the back end of the front torsion bars.
Seal goes under the caps.
Rod
1986 Carrera
2001 996TT
Old 02-26-2019, 06:54 AM
David's Avatar
How about the front bushing of the front torsion bars? It's wide open especially if you replace the original tow hooks with the Rennline hooks. I was thinking about stuffing some valve/pump packing in there but a foam ring might be better.
Old 02-26-2019, 07:55 AM
David you should have a dust cap on front of A arm to protect front torsion bar. Maybe yours are missing
Old 02-26-2019, 08:53 AM
I would rather be driving
jpnovak's Avatar
Neoprene sheet works well. Recycle an old mouse pad...
Old 02-26-2019, 09:09 AM
Counterclockwise?
Not springy enough. Maybe use foam?
$5.00 each from Porsche is starting to sound cheap.
Rod
1986 Carrera
2001 996TT
Old 02-26-2019, 09:35 AM
Exactly what I did. The foam ring fit right in and I added some grease to the foam to help repel water. Covers are gone, replaced with Rennline tow hooks. Been there for several years, working perfectly.
1986 3.2 to 3.4 conversion
Old 02-26-2019, 09:37 AM
disband
juanbenae's Avatar
me too. they are to keep dust out, not so much to water proof.
Old 02-26-2019, 11:53 AM
proporsche's Avatar
actually, the original foams were soaked with some kind oily compound so it was semi- waterproof...it was on every 911 but mechanic were lazy to put them back from my experience;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-26-2019, 12:53 PM
Counterclockwise?
Ivan
And they had completely fallen apart like mine.
Rod
1986 Carrera
2001 996TT
Old 02-27-2019, 06:36 AM
proporsche's Avatar
yup ,they will in 25-30 years they do go bad;-) I wonder how long those from nowadays will last;-)?
Ivan
Old 02-27-2019, 07:10 AM
Counterclockwise?
I took mine off as I'm doing a major cleaning.
Doubt they will ever come off again.
Rod
1986 Carrera
2001 996TT
Old 02-27-2019, 07:45 AM
The stock material is an open-cell foam; it's more of a sponge/filter than a seal. If you want a better "seal", you need either a closed-cell foam (think water pipe insulation extrusions), or solid rubber.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 02-27-2019, 08:09 AM
disband
juanbenae's Avatar
Ivan
most foam based air filters are oiled to aid in capturing and holding dust. im not saying there is no advantage to them in regards to water intrusion, but as I recall they are referred to as dust seals. I agree that them being oiled will also help in repelling water. unoiled they might catch and hold water which as we all get is the worst possible case scenario.
Old 02-27-2019, 08:58 AM
proporsche's Avatar
yup ,good point no wonder the torsion bars were powder coated;-)and they squeak once they are worn out;-)
Ivan
Old 02-27-2019, 10:08 AM
Counterclockwise?
Ivan
No squeaking with the mess of grease from the polybronze bushings.
Rod
1986 Carrera
2001 996TT
Old 02-27-2019, 11:00 AM
