Engine keeps running after ignition key is turned off
I have a 1979 SC backdated to a 911R that I bought from Jim Tweet on here. The built post is on Pelican as well.
The engine is pimped out with ITB’s, EFI and an AEM Infinity ECU.
If I turn the ignition key to off, the engine will keep running until I press the brake pedal.
What could cause this? How do I fix it?
Dan
Old 02-27-2019, 01:04 PM
Dan
Contact Andrew from Rasant, at the time I installed his kit he was not including a alternator relay. It has to do with power back feeding from alternator into the ecu. I believe he has a fix for this now.
Old 02-27-2019, 01:44 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Plenty of threads on this. Do a search.. You will need a new or to add a diode.
Marc
Old 02-27-2019, 03:37 PM
