-   -   Jacking points (http://forums.pelicanparts.com/porsche-911-technical-forum/1022544-jacking-points.html)
Flojo 03-05-2019 11:07 AM
Originally Posted by 7783911 (Post 10378337)
Flojo..idea on when and cost?
not jet. we elaborate the finish... either diamont cut surface ore plain anodized black
Includes bolts to mount?
that's the plan, ready to bolt on.
Maybe even with the needed nut in case some cars dont have it, so you can Weld it in.
will keep my instagram updated
tmadden2 03-05-2019 11:31 AM
Following. I’m interested to know more about these jack pads as they develop.
walt 03-05-2019 01:49 PM
Maybe consider making these from Delrin or similar. Very tough material and no post finish required.
7783911 03-07-2019 12:15 PM
can some one tell me the bolt size/thread for these mounts?
thanks
Bob
Flojo 03-07-2019 01:22 PM
thanks
Bob
guess its M10 (?)..., just lift the carpet, find the nut and try it out.
7783911 03-07-2019 01:36 PM
if the car was here I would, in shop getting heads done
Flojo 03-07-2019 01:40 PM
https://up.picr.de/35229175ml.jpeg
https://up.picr.de/35229177ia.jpeg
7783911 03-07-2019 02:46 PM
thank you
Koizumi 03-07-2019 09:15 PM
Those custom bolt-on pucks look awesome. I’d sure like a set
Flojo 03-08-2019 12:01 AM
follow me in IG: https://www.instagram.com/spadescustomz_/... soon to come.
wds1429 03-12-2019 02:08 PM
I have an 86 911 and I cant seem to locate these 10mm threaded holes.
Can anyone give me some guidance ?
Thank you
Bill
7783911 03-13-2019 04:51 AM
wds, advice given me was lift carpet and you should see the capture nuts...
wds1429 03-13-2019 01:35 PM
Thank you , I will follow that advice...
chrismorse 03-19-2019 08:19 PM
My 74 seems to have weep holes not threaded bosses
Are there threaded bungs, or inserts that can be welded in to fit these slick lifting pucks, a molly anchor seems kinda light in its absence??
Chris
Uwon 03-20-2019 05:21 AM
Chris
Why not use a nut. It’s all covered by loose carpet in the corners.
Johan
tmadden2 10-13-2019 04:58 PM
Originally Posted by Uwon (Post 10376385)
There are 10mm (check size) threaded holes at each corner of the belly pan, just next to the pinch welds. Get yourself four hockey pucks, drill out the centre, including a recess for the bolt head and screw them in. As I recall, on one corner I also had to saw a slit on the puck as the threaded hole is too close to the pinch weld.
Johan
What do you think the odds are that those threaded holes are a carry-over from attachment points to this kind of overhead crane system on the early 911s?
https://uploads.tapatalk-cdn.com/201...361bdcbf84.jpg
Jack Stands 10-13-2019 06:09 PM
Hockey puck jack points
A few minutes with a Drill press and a Forstner bit and you can fabricate your own. You may find at AC lines may interfere with the attachment points however.http://forums.pelicanparts.com/uploa...1571015314.jpg
gduke2010 10-13-2019 06:15 PM
I bought the Esco jack stands from Pelican Parts with the round rubber tops. Quality stands and I bought a pair of axel posts which I use under the solid torsion bar or torsion bar covers. I glued rubber on the posts with contact cement.
Like to put the stands under the torsion bars or torsion bar covers. I have a cabriolet and the door reveal doesn’t change much while on stands .
gduke2010 10-13-2019 06:17 PM
Btw, haven’t seen the screw holes at the jack points. Have a 1985.
Flojo 10-15-2019 05:43 AM
I'm not quite sure but I believe these fixture to vanish around early 3.2s
just drill yours.
