FPH Gruppe
How many years will the rubbery end of a German turn signal last?
46, in my case:
Who can I call in upper Management at Porsche about this horrible failure? Short of that, anyone ever source just the rubbery cover bit? Our host has the entire switch and harness for the rather staggering cost of $463.75... I'll try something else before parting for that kind of scratch... I am trying Gorilla glue but I doubt I'll get another 46 years of service out of it...
Skip Newsom 72 911T Targa Signal Yellow Now sporting a big Port 3.0 built by THE John Walker |
ROW '78 911 Targa
They just don’t make em like they used to...
JB Weld
You could always be super creative. Carve a replacement out of wood, rivet it in, stain it, buy matching wood steering wheel, be the only person with a matching wood steering wheel and turn stalk.
Option two would be to try 3D print a two piece replacement that gets sandwiched on and epoxied. You could then coat it in plasti-dip or something if you still wanted the rubber feel. |
FPH Gruppe
Thanks for the ideas!
I did consider caving a replacement out of oak... it would look great. Still hoping there is an off the shelf replacement option out there.
Pelican Parts Vendor
West System G/Flex is one of the best epoxies you could try for something like this, it allows some flex as opposed to most rock-hard fast-set epoxies. But if the aged knob material is weak, it could just break again next to the epoxy. Gorilla Glue sets by reacting with moisture (from the air, or dampened wood) and expands as it sets, so it may widen the crack in the knob a bit.
An oak carving might just look fantastic, would love to see it if you end up going that route. |
Our host sells replacement ends.
FPH Gruppe
I may be looking right past it but I don't see it in the parts listed in the link Harry sent.
That link is for 74-89... my car is a 72. I see the entire switch, my switch still works perfect, I'm looking for just the rubbery tip that's epoxied on from the factory or switch supplier. One drive and several uses of the Gorilla glued original seems to be holding, as UROParts noted the entire rubber cover is likely to fail in some other spot. Mine broke when I flashed the headlights at my nephew as he was going past me. If someone sees a part # for just the rubbery tip of the signal switch please let me know! Many thanks!!!
901.552.853.00
1989 911 Targa |
Runnin on empty
Google 901.552.853.00 it's $20.98 at a another vendor.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
FPH Gruppe
Awesome gents!!!
Thank you, Thank you! I may still try to carve one out of oak, but now I have a fall back plan... it's bound to fail again...
One can allways buy an aftermarket replacement later...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Member 911 Anonymous
$10+/- per year ain't bad. :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I'm good with tools.
My blinker hasn't been used in years, but my middle finger has many times.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Guest
Posts: n/a
^^^ I'd stick with this distinctive look! |
I saw something like this design in the latest Singer. Nicely done!
Tru6 Restoration & Design |
I find the Porsche PET to be a very valuable resource.
81SC Coupe Tony Kart/Yamaha Last edited by 81SC; 09-27-2018 at 12:26 AM.. |
Just search by part # here on the Bird: 901 552 853 00 M253 Uro part, $20-
