Targa_PB_78_SC
Rich/lean mixture test question or explanation
I’ve seen a reference to a simple lean/rich test of mixture for CIS herein. Having trouble finding an explanation of it.
If car is idling and one pushes the sensor plate up slightly and the car stalls/dies this means what? Maybe a better question: is this test and the results defined somewhere? |
Giving it too much fuel and the throttle opening is closed so it’s a stall situation
Call me this evening and I’ll explain it to you Bruce |
1983SC RoW Last edited by SkiVT; 03-11-2019 at 12:43 PM.. |
lifting the sensor plate DOES NOT add air.
that controls fuel ONLY. air is still limited or controlled by the throttle body. lifting the pate ADDS fuel. if it runs worse when you lift it then you are too rich. opposite for pulling down
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 03-12-2019 at 04:33 AM.. |
Thanks for the correction (deleted the bad info so nobody gets confused). I should have known I was backwards as the other end of the arm hits the plunger.
1983SC RoW Last edited by SkiVT; 03-11-2019 at 12:44 PM.. |
Targa_PB_78_SC
Appreciate the information guys.
In the process of troubleshooting I decided to place a piece of cardboard over the mouth of my air intake. I thought well no air the car should die. No it kept on running. When I pulled the accelerator I could feel suction on same cardboard. Still kept running, expected? |
This was posted a few years ago- it has helped me
If you move the air plate up slightly with a resulting rough or surge, you are closer to the rich extreme. If you have a 3mm Allen wrench handy, you can turn the mixture screw counter-clockwise to lean it out a little, maybe 1/8 of a turn, then repeat. To get it just right, you’ll have to develop a touch and maybe even a sense of smell. To test for lean, you can pull down on the arm slightly and get the opposite effect of the rich test. That’s it! That’s all there is to it. |
I don't think you should be able to stall it out covering up the intake. If it kept running smooth with the intake covered then I think that would be a pretty good test for a significant vacuum leak.
This is the best thread I ever saw about using the sensor plate method. CIS Idle Speed and Mixture Setting Without an Analyzer Last edited by gazzerr; 03-11-2019 at 07:07 PM.. |
Targa_PB_78_SC
Knowledge is key ![]() Humm ... and from it I was reminded of a wideband analyzer which I own. I might ... humm |
Targa_PB_78_SC
Seems some folks (CIS tech troubleshooting guide from Porsche) do not think my leak is significant enough to pursue, because the throttle body idle adjust screw caused the engine to die when I screw it in. "Don't we wish we could live forever with so much to learn", is a quote I recall from my advanced engineering mathematics professor. This was before my Porsche was a couple of years old . And in a different owners hands.
Targa_PB_78_SC
And for my wideband sensor it says 14.7:1. hum I'll assume my sensor gets installed into the plug off the cat converter ... ? Probably another thread on this somewhere too ...
No worries. Yes agree so much to learn
.The easiest way to find leaks is to smoke test it. You can buy a cheap smoke generator that works with baby oil. |
This video link is also something I have found useful. There is a specific description of how the plate works with air and fuel.
https://www.youtube.com/watch?v=a4fJAfXYxWk This pic may also inform your other question on AFR as I think 14.7 is on the lean side of what your year engine might like or at least performance wise, be optimal.
1983SC RoW |
