Kevin G's Avatar
Strange Idle
I started my car up recently after the winter months. Can someone tell me why I couldn't get it to idle until I took off the oil cap. Put the oil cap back on and it oscillates and then dies. Last fall I had the manifold boots and gaskets replaced and after that, at times when started cold, it would hunt for a steady idle. Don't know if the mixture was set incorrect or I need to change the idle. Any idea's appreciated.
Thanks Kevin
Kevin 79sc - Timing is everything.
Old 03-16-2003, 09:15 AM
Formerly bb80sc
Vipergrün's Avatar
I'd say your mixture is too rich and letting the additional air in thru the cap leaned it out enough to run well.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 03-16-2003, 09:41 AM
rstoll's Avatar
Stale gas?? Maybe a bottle of Techron and a fillup are in order.
Robert Stoll
83 911 SC
83 944
Old 03-16-2003, 09:58 AM
Mark Wilson
Guest
Posts: n/a
CIS idle hunt problem found
Old 03-16-2003, 10:06 AM
Kevin G's Avatar
Thanks for the replys, I leaned out the mixture and sure purrs like a kitten now. Time to drive around, it's been 4 months in Wisconsin since the weather has been good and 60 degree days in March are hard to come by.
Thanks again!
Old 03-16-2003, 11:12 AM
rstoll's Avatar
Kev, do you have a pop off valve in place?? Lean mixture will make her pop.
Robert Stoll
83 911 SC
83 944
Old 03-16-2003, 11:22 AM
