Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
hal,
Let me know when you're coming by. You're welcome to come by my home home and see the 'turd. I'd love to see the 2.5 as well.. It's one of those early screamers that I really like.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-19-2003, 10:49 AM
Alan.UK's Avatar
I have both a 71 E and 71 S. When the S hits 5k its just so much fun, but the E is not that far behind in terms of performance. I will have a look in the E handbook later today.
Old 03-20-2003, 09:59 AM
1971 911T's Avatar
old thread but a 2.2E MFI stroked to a high-comp 2.4E rebuild with all else unchanged was dyno'd on Thursday. CR was 9.1:1. Torque was 160lb/ft from 3,700RPM almost horizontal to a 165 peak, dropping off above 6200rpm. Hp peaked at 192+hp, at 6,400rpm. On a dynomite, SAE. will post data later. Sweet!
Reza
Old 10-22-2011, 06:03 AM
Home of the Whopper
Reza
I would love to see the plots. This is the EXACT engine I am building for my '71E sporto coupe.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 10-22-2011, 06:41 AM
1971 911T's Avatar
Engine built by Mark Burkit at Specialty Cars, Allentown, PA
flywheel SAE. this was the first run, the best run was 192.5hp. Overall, not bad for an E and a mere 2.4.
was told that the bump below 4K is the load coming on.
Reza
Old 10-26-2011, 02:40 PM
