hal,
Let me know when you're coming by. You're welcome to come by my home home and see the 'turd. I'd love to see the 2.5 as well.. It's one of those early screamers that I really like.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
I have both a 71 E and 71 S. When the S hits 5k its just so much fun, but the E is not that far behind in terms of performance. I will have a look in the E handbook later today.
old thread but a 2.2E MFI stroked to a high-comp 2.4E rebuild with all else unchanged was dyno'd on Thursday. CR was 9.1:1. Torque was 160lb/ft from 3,700RPM almost horizontal to a 165 peak, dropping off above 6200rpm. Hp peaked at 192+hp, at 6,400rpm. On a dynomite, SAE. will post data later. Sweet!
Reza Last edited by 1971 911T; 10-22-2011 at 06:09 AM.. |
Home of the Whopper
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Engine built by Mark Burkit at Specialty Cars, Allentown, PA
flywheel SAE. this was the first run, the best run was 192.5hp. Overall, not bad for an E and a mere 2.4. ![]() ![]() was told that the bump below 4K is the load coming on.
Reza |
