I think that should be the speed ‘ref’ sensors (reference)
Shirish 1987 Carrera, Granite Green |
Check all engine bay hoses - breather and vacuum.
There is a circa 1” wide vacuum hose that joins the chassis in front of the engine, onwards toward the brake booster. Do check that - mine fell apart upon inspection ..
shh-the robot is sleeping
Every 30 years rebuild your axle halfshafts.
'88 911 Coupe, 69k miles |
Get the intake smoke tested, find vacuum leaks early before the cause real damage. Most cars I look at these days have some sort of intake air leak.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
fuel lines, fuel lines, fuel lines. My 1985 has had two major leaks and I found the third luckily before it happened. You say they were checked...but if they are original and 35 years old, I would change them before it is too late. My car has 250,000 miles and still runs fine.
I just did this...
![]() ![]() ![]() So, I wish I'd had this... https://www.rsrproducts.com/product-page/rsr-products-rear-sway-bar-mount-gusset-kit New WEVO mounts getting welded up next week.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Agree on replacing the 2 reference sensors, CHT, fuel lines, intake gaskets and also check the distributor bushings. My bushings at 100K were fine however, my brother in laws 911 at 100K found that the rotor was beginning to touch the cap due to the upper bushing being worn out. And of course - yes, drive it!
1986 Targa Guards Red 2021 MT09 SP |
This!
Richard 87 Targa 20 LS 500 |
