MSD Setup for my new 3.2 SS build
Been searching and have read many posts about different MSD setups and was hoping someone had a great link or could just tell me what setup to use.
Which Control Box? 6425 6AL or the Street Fire? Which Coil? Blaster 2, Blaster 3, or High Vibration? WhichSpark Plug wires? Which ones? Any other special connectors? Tricks? Thinking of mounting control box in the car to keep engine bay clean as I have carbs. Thanks for any feedback.... Joe |
I've used Streetfire with a high vibration coil on several car and they have always worked great
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
(man/dude)
There is a programmable option from MSD too that would allow you to lock out the mechanical advance in the distributor and program your own curve.
Could be handy, and save you from having to recurve the distributor (a task that may be so out of style that nobody knows how to do it anymore!!) Last but not least there is the CDI+ option if you want to maintain a more or less stock looking option without having to disturb the wiring. I vote with my wallet when I see products I like and I really appreciate that Classic Retrofit is developing innovative new products specifically for our cars.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 03-21-2019 at 10:32 AM.. |
^ A wire wheel, and a <$10 pack of spade terminals and connectors from Mouser/timmyd and I converted my Streetfire box into an OEM look. I was all in for under $250 so it was a no brainer compared to the more modern options.
Thanks guys for the feedback. Should have mentioned that I doing PMO Carbs. Was thinking about mounting the box inside the car to keep the engine bay clean.
Add this to the ignition solution and you have a decent fully programmable ignition.
https://hotvws.com/content.php?contentID=96
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
This is a very interesting product
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
