The 9 Store
Performance products slick shift
Found this in a pile of stuff. It’s nos. I’ve never seen the kit before. Any value?
All used parts sold as is.
Old 03-28-2019, 11:20 AM
proporsche's Avatar
it is a kit we used to install in the 1980`s and 90`s..Very inexpensive way to have a short shift and works well
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-28-2019, 11:29 AM
scumbag
I'm pretty sure that is exactly what is in my car. I can give feedback if/when I ever get the engine/trans back in it.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 03-28-2019, 11:42 AM
Vintage Owner
Jack Stands's Avatar
I have it in my 914-6 and it works fine.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 03-28-2019, 11:44 AM
The 9 Store
Any Idea on price? I have a Rennshift. I don't need it.
Old 03-28-2019, 12:05 PM
proporsche's Avatar
hi mep...here is the price as it was back 2008
Ivan
Old 03-30-2019, 09:27 AM
The 9 Store
Old 03-31-2019, 11:50 AM
Walt Fricke's Avatar
I don't think you will be able to retire on what you get for this. There are a couple of problems with these kits. The first is that eventually the epoxy you use to hold the new ball piece on will fail. More importantly, while this reduces the fore and aft movement of the shift lever (which is what you want), it also reduces the side to side movement. You don't want that - having the side to side distance of the shift planes closer means it is a lot easier to get the wrong gear.
But someone will probably pay a few bucks. The best short shifter for the money is the factory one, which changes the side to side pivot axis so your hand still goes where it is used to going, just not as far forward or backward.
Old 03-31-2019, 02:59 PM
joe payne's Avatar
I had that kit on my stock shifter. My mechanic hated installing it because of the center console removal. Other than that it worked great and was 40 bucks! Now I have a RENNSHIFTER.
jtp911
Old 04-01-2019, 07:00 AM
The 9 Store
Thanks for all the info guys. I will post it in the FS section.
Old 04-01-2019, 10:29 AM
