-   -   Diagnosing CIS Components from Pressure Test (http://forums.pelicanparts.com/porsche-911-technical-forum/1025162-diagnosing-cis-components-pressure-test.html)
wreckah 04-04-2019 11:20 AM
Hi Joe,
might be an idea to look for a full intake with all the assorted bits off a donor car? 1980 intake openings on the engine might be smaller than earlier engines (dunno for sure when that changed) , so you might run into troubles with that.
Whatever you do, do not be tempted to try and put lambda on your CIS system, it is the worst with regards to troubleshooting, difficulty of install, complexity, etc...a bandaid on a bandaid on a bandaid.
Try and find a 78/79 WUR and FD combination that has been proven to work on 3 liter SC cars. That's the basics of it. Maybe have them rebuilt. Then test with wideband. The rest is of secondary importance. (auxiliary stuff for warmup etc)
cheers, Jan
JoeyD1005 04-04-2019 11:35 AM
Originally Posted by wreckah (Post 10416368)
Hi Joe,
cheers, Jan
Thanks for the input wreckah.
Yeah after some late night reading, I was able to decide to source a -033 Fuel Distributor as well as a -045 Warm up regulator. Once sourced, I'm going to do a proper backdate and clean up the engine once its out of the car. From there, i'll ensure vacuum routing and such will be back to 78 spec.
I read that most people only run into this problem when putting early runners on a late model 3.0 motor. you are correct the runners are differently sized in diameter. I plan on just swapping out my FD and keeping the same intake runners while pairing it with the correct WUR. I do plan on putting in a bung for an 02 sensor in general - even if just for diagnosis and then have it plugged when not in use.
Who knows once I get it out though, you know how it goes.
-Joe
boyt911sc 04-04-2019 12:47 PM
Fuel distributor.........
Joe,
Is that a typo? You need WUR-045 and FD-031. Not FD-033 (?).
Tony
JoeyD1005 04-04-2019 06:41 PM
Originally Posted by boyt911sc (Post 10416499)
Joe,
Tony
You are correct my man. Apologies I wrote this whole escaping extinguishing a fire at work. Head wasn't in the game evidently!
pmax 04-05-2019 10:47 PM
Hi Joe,
Yes, don't install the lambda controller if the car doesn't already have the wiring in place.
However, the good closed loop control of the AFR to allow cleaner running at "cruise" is a good thing for the engine, while getting out of way going to open loop during WOT.
cheers, Jan
Wrt complexity, some components such as WUR are simpler on the lambda cars with the vacuum controlled function replaced by the newer system.
