-   -   Diagnosing CIS Components from Pressure Test (http://forums.pelicanparts.com/porsche-911-technical-forum/1025162-diagnosing-cis-components-pressure-test.html)
JoeyD1005 03-30-2019 11:32 AM
Hey Everyone,
First off thank you for any help in advance, I've been doing quite a bit of reading and I'd like to try and provide as much information as possible for what I'm hoping is an easy diagnosis.
Car: 1978 Porsche 911SC
Background : First nice day rolled around in Michigan and I was going to try and take my car out for a drive. Unfortunately, I was having some trouble starting it. For the first few attempts, the car cranked but wouldn't start. After cranking for some time, it would kind of have a very weak burp type of a fire after I stopped cranking. With no luck after a few tries, I gave my starter a break and said I'll come back to it. After about 30 mins, the car reluctantly started and I let it warm up. Pulled out of the garage, seemed to be running a little rough but thought it could just be because it was stored all winter on bad gas so I ran to the sation up the street for some 93. On the way there, the car died twice at a light and I had to keep revs up with the car in neutral at lights and breaking. Got it home and started doing some research.
What I've Done So Far: Upon some general reading I decided to perform some general vacuum leaks. To do this, I uninstalled some of the heater piping so that I could spray some carb cleaner around the injectors and airbox. No change in idle.
Once the car has warmed up for some, I removed the oil cap and the idles dropped 1-200 ish RPM and the idle became a bit rougher.
Took out the airbox and tried to see if there was any sign of mixture related issues by doing the field test with the air plate. Seemed generally to be right in the middle of rich surge and lean. Decided not to even mess with mixture to keep variables in check. On to the CIS pressure test.
CIS Pressure Test Procedure:
1)Connected Fuel Guage between Fuel Distributor and WUR (Ball Valve on WUR Side of T Fitting)
2)Jumped FP Relay Socket
3) With Ball Valve Closed, ran Fuel Pump : System Pressure read 75 PSI (5.17Bar)
4) Opened Ball Valve w/ WUR Unplugged : Cold Control Pressure read 12 PSI (0.69Bar)
5) Kept Ball Valve open and plugged WUR connector back in:
- 1 Min Reading : 12 PSI (0.82Bar)
- 2 Min Reading : 18 PSI (1.24 Bar)
- 3 Min Reading : 22 PSI (1.52 Bar)
- 4 Min Reading : 25.5 PSI (1.76 Bar)
6) Kept Ball Valve Open and Shut off Fuel Pump:
- 0 Min Reading : 28 PSI (1.93 Bar)
- 10 Min Reading : 24.5 PSI (1.69 Bar)
- 20 Min Reading : 23 PSI (1.59 Bar)
- 30 Min Reading : 22 PSI (1.52 Bar)
Notes: I ran this test with NO vacuum to the WUR. I am not sure if that is something that is required on this year. I unfortunately am not able to see from where I looked any sort of part number designation for the WUR from where I checked. Between the top vacuum line and the electrical connector I only see the word BOSCH. I did however see that there is a vacuum line off the drivers side of the WUR (away from center of engine) that does not have any vacuum cap or line that has fallen off.
From what I have read on the CIS Primer site, it looks as though my WUR control pressures are lower than what is expected by the engine. Am I correct in suspecting that this is my main problem?
Please let me know if there is any more info needed for the discussion, I will try to get it asap.
Thank you again!
-Joe
JoeyD1005 04-01-2019 10:52 AM
After some more digging around int he engine bay, I was able to determine that the part number for my WUR is 033
Hope this provides a bit more info for diagnosis.
pmax 04-01-2019 12:34 PM
Nice work.
0438140033 is a 76-77 WUR.
I would also run the same tests with vacuum applied on the port to see if the WUR is adjusting the fuel pressure accordingly.
JoeyD1005 04-01-2019 12:46 PM
Thanks for the feedback, I can redo the test again tonight with vacuum. I unfortunately do not have any electric vacuum pumps. I do however have a mighty vac that I use for brake bleeding. What is the appropriate amount of vac to put on these lines, also do I pull vac on both fittings? On the 033 regulator, it looks like there is one on top and one on the left hand side.
If the test still shows low control pressure, is it time to make it an adjustable WUR? and tune with the CIS guages for control pressures?
I also saw today that I can do a resistance check on the electrical points so I can do that at the same time. Is 18-22 Ohms the expected reading?
Last question, is the mentioned startup and running problems inline for what we would expect for lower control pressure or do you think there might be another issue at hand?
Thanks for any advice.
-Joe
pmax 04-01-2019 01:22 PM
Vacuum applied from a manual pump should do, to the lower vacuum port. The port on the top is to "atmosphere". Another CIS elf which might be malfunctioning is the thermovalve, in line with the WUR vacuum prot, which controls the application of vacuum in your 78.
Yeah, it could. Adjustable is great for tuning your WUR. These are hardly precision devices given the >20% slop in the acceptable operational band.
JoeyD1005 04-01-2019 01:36 PM
Sure, I can run it again with vacuum on the side port. Any thought as to how much vacuum is on it?
JoeyD1005 04-01-2019 01:43 PM
Quick resistance check at the plug shows about 26.5 ohm. Out of spec on the diagram I saw, but it looks like another post says between 20 and 30 is fine. Hoping metal strip is functioning as expected and just takes a bit more time to heat up.
Any thoughts?
pmax 04-01-2019 02:04 PM
Around 7-8 psi I believe.
http://forums.pelicanparts.com/porsche-911-technical-forum/758788-cis-troubleshooting-dummies-5.html#post9681535
Yeah, the strip is working given the rising pressure vs heating time in your test. As you surmised, just takes more or less time to warm up ... in minutes, no big deal.
boyt911sc 04-01-2019 02:14 PM
Nope.........
Originally Posted by pmax (Post 10412698)
Vacuum applied from a manual pump should do, to the lower vacuum port.The port on the top is to "atmosphere". Another CIS elf which might be malfunctioning is the thermovalve, in line with the WUR vacuum prot, which controls the application of vacuum in your 78.
WUR-033 has the vacuum port on top. You must be thinking on WUR-045/-069/-089. The early CIS WUR’s up to ‘77 (WUR-033) was the last group of WUR’s for 911 using the top post for enrichment. ‘78~’83 RoW (without lambda) are all using the side nipples for vacuum enrichment. ‘80~’83 (with lambda) do no use vacuum assisted WUR’s.
Lastly, you could use WUR-033 in your 3.0 engine provided you use the correct vacuum connection from top instead of side nipple. However, these WUR-033’s are not as robust and steady as the later WUR’s (-045/-069/-089) as far as enrichment is concerned.
Post some pictures of your engine and see what you have there. Where does the vacuum line to WUR-033 in your motor connected? Picture will help. Thanks.
Tony
JoeyD1005 04-01-2019 02:17 PM
Tony
Hey Tony,
I'll run out and grab some pictures after dinner.
From memory of about 20 mins ago, the vac line from the top of the port goes to a T fitting and feed of that vacuum line goes into somewhere near the throttle body.
Should the 033 model have vac on both top and side ports?
-Joe
boyt911sc 04-01-2019 02:38 PM
CIS troubleshooting.........
Originally Posted by JoeyD1005 (Post 10412780)
Hey Tony,
-Joe
Joe,
If you have a hand held vacuum pump like a Mity vac use it to measure your WCP (warm control pressure) @ 16” Hg. From the initial data I saw from your early posts, the WUR-033 needs some calibration. BTW, you got the wrong WUR for your ‘78 SC. You could make it to work. I actually used a WUR-033 in my ‘78 SC for a while till I found a -045 three (3) decades ago. And that’s a long time ago.
To answer your question:
WUR-033............vac @ top post/atmospheric @ side nipple. For WUR-045/-069/-089 it is the reverse or opposite. Be aware of this difference between these WUR’s.
Tony
JoeyD1005 04-01-2019 02:49 PM
Originally Posted by boyt911sc (Post 10412796)
Joe,
Tony
You're the man Tony, much appreciated.
I'll run out and re-perform the checks and be back with the results.
-Joe
JoeyD1005 04-01-2019 03:10 PM
So a lot different results now that there was vacuum on the top port:
Temp = 40F
System = 75 PSI
CCP = 12PSI
1Min CP = 16PSI
2Min CP = 22PSI
3Min CP = 29PSI
4Min CP = 34PSI
5Min CP = 36PSI
6Min CP = 39PSI
6Min CP = 41PSI
Vacuum on Port = 16" Hg
JoeyD1005 04-01-2019 03:42 PM
Uploading some pictures of the engine bay:
1) Shows the Vac T Fitting (1 port to throttle body, 1 port to WUR, 1 port to vac cap
http://i623.photobucket.com/albums/t...sqgzoagbe.jpeg
2) Shows the vac source from throttle body (Dark Blue line, Red line goes to spark distributor)
http://i623.photobucket.com/albums/t...sncbjvitr.jpeg
3) Shows this hack of a vacuum cap (will be fixing asap)
http://i623.photobucket.com/albums/t...sydi2uiyt.jpeg
T77911S 04-02-2019 03:54 AM
41(2.7bar) is still too low. you should be around 3.6bar and have about a .8bar drop when you have no vacuum.
.7bar could be low depending on your outside temp and if you have the TV. the TV will block vacuum when cold dropping the CP even more for cold starts when it is really cold out.
BUT, if that is where the CP was when someone set your mixture then just leave it for now and get it running how it was before.
check for vac on the line going to the WUR at idle. this line should goto a thermo time valve (TV) (you may not have it and that is ok. ) then it should goto the decel valve (DV) with a "T" and then to the TB. it needs to goto manifold vacuum, its one of the ports below the throttle plate. (i may be wrong, too many years now, but i am thinking it was on the back, but could be wrong).
check your pop off valve and make sure it is seated properly.
my 033 would be .8bar when really cold, then 1.8bar once vac applied when cold then it would warm up to 3.6bar with vac and 2.8 without.
you may get away with adjusting your pressures.
tony can even check your WUR for you if you send it to him
top port is vac, side port is a vent that goes to the intake (no vacuum). it there in case of fuel leak inside the WUR
boyt911sc 04-02-2019 05:24 AM
Mystery line.......
Gilbert,
What is this mystery line? Where does the line connect to? Never seen one before and curious to know. Keep us posted. Thanks.
http://forums.pelicanparts.com/uploa...1554211353.jpg
Tony
JoeyD1005 04-02-2019 06:21 AM
Originally Posted by boyt911sc (Post 10413364)
Gilbert,
Tony
Tony, that is sort of some weird brass adapter that goes from the small vacuum line from the T junction to a larger hose to fit over the vacuum port on the top of the WUR.
-Joe
JoeyD1005 04-02-2019 06:29 AM
So I can tell you right now that the vac routing that you posted is not what is in my car. Since one of the lines coming off of the T fitting has a freakin golf tee in it, the routing is effectively going directly from the WUR to the throttle body (the dark black vac line I showed) it is on the drivers side of the throttle body. Not sure if that is correct or not - I'm guessing it is not.
So I will go check for a thermovalve and decel valve when I get home and see if the vac routing is just completely borked.
Car ran and drove fine for the last two years until this spring. I'm guessing that it wasnt running at peak but unfortunately I didn't know due to it being my first 911. Ill be happy to get all of this sorted out.
SkiVT 04-02-2019 08:19 AM
I believe if you envision the blue line coming off the top of your WUR (ignore the yellow line), the rest of the vacuum routing through TV and DV is accurate.
http://forums.pelicanparts.com/uploa...1554221755.jpg
JoeyD1005 04-02-2019 08:32 AM
Correct, except I have a 033 wur so the ports are flipped on part 5 of the diagram. Ill take a look at it when I get home.
pmax 04-02-2019 08:55 AM
Yes, that diagram is for the 78 which you do not have exactly. 045 vacuum on the side to the TV as above.
2.7 is low for the 033 w/ the 8psi vacuum applied.
JoeyD1005 04-02-2019 09:13 AM
Pmax, so if i can fix any sort of vacuum routing issues and the tests still remain somewhat the same, should I plan on modifying my 033 WUR?
Seems like Tony indicated that it should work as a holdover solution until I can come across a 045 wur.
-Joe
pmax 04-02-2019 09:30 AM
-Joe
Go as recommended. 2.7 appears to be OK at the low end of the correct 045 for your 78. Just pointing out that it's low for the wrong 033 you have !!
http://forums.pelicanparts.com/uploa...1474820304.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/930419-1978-1979-911-sc-cold-control-pressure-graph-0438-140-045-a.html
JoeyD1005 04-02-2019 11:44 AM
Feeling not so fantastic after looking to verify vacuum routing.
Looks like PO deleted the throttle valve as well as the decel valve.
Was able to determine that the red vacuum line runs from a port on the back side of the throttle body directly down to the ignition distributor.
Also while rooting around in the engine bay, I discovered a loose fuel line i'm guessing. It's plugged with a bolt but i don't get the warm fuzzies now. Took a picture of the splitter it connects to.
See pics below:
JoeyD1005 04-02-2019 11:50 AM
Where I expected to find decel valve
http://forums.pelicanparts.com/uploa...1554234531.JPG
JoeyD1005 04-02-2019 12:03 PM
Mystery Hose on rear left side of engine bay:
http://forums.pelicanparts.com/uploa...1554234656.JPG
Splitter that mystery hose terminates to:
Right Passengers Side of Engine Bay for Reference:
http://forums.pelicanparts.com/uploa...1554234809.JPG
Lower Passengers Side of Engine bay for reference:
http://forums.pelicanparts.com/uploa...1554235003.JPG
boyt911sc 04-02-2019 01:49 PM
CIS components...........
Joey,
Right now, your WUR-033 is not in a good working condition. It will need some adjustments and calibration to make it work. You will probably lose the whole springtime or even summertime trying to fix or solve your problems.
I have a few WUR-045 that I could loan you to try and test in your car. It is a loaner and you are no obligated to buy it. You will have an opportunity to experience and see how a good working WUR performs. You also need a TTV and DV to replace your missing components.
http://forums.pelicanparts.com/uploa...1554240984.jpg
Send them back to me after the tests in the same condition you received them. PM me if you are interested.
Tony
JoeyD1005 04-02-2019 04:01 PM
Tony,
Thank you for your comment - sent you back a PM.
Also did some more sleuthing around. Ran the engine number through some reference material I found online - looks like this car has a donor engine from a 1980 car which explains why the DV is not in the expected location. I can now confirm that the DV is present on my car. TTV i still need to track down, but this helps a lot.
Cross referenced bosch WUR production chart and looks like 045 is still the money maker.
Looking forward to testing it out.
-Joe
juanbenae 04-02-2019 04:26 PM
poor, poor pnutz. his sansei harshed him with bold font quoted portions of this to illuminate his mis-information... AND then he admits "these are hardly precision devices", a carbman could not live that way!!!
living in a stone cavern can stunt my internet, but even this caveman saw that emboldened font spanking on nutz.
poor, poor pnutz.
pmax 04-02-2019 05:00 PM
Sure, carbman jb :)
The superiority of CIS over carbs is a given even with that slop.
Carry on. Let's not derail Joey's thread, shall we ?
juanbenae 04-02-2019 05:06 PM
come on nutz! you gunna drop the "caveman" slop on me from time to time in unrelated threads and be off scott free? yet when I go eyewitness news on you after being spanked by CIS tony himself you are gunna whine about it?
I hope the OP gets his situation here satisfied, I do. but don't play with the bull if you cant handle the horns.. silly, silly pnutz.
toby
PS- your multiple replies & edited posts tell your tale... silly man
pmax 04-02-2019 05:13 PM
You picked the wrong thread JB. But good thing you are following the details so closely and learning all about the CIS tidbits ! Carry on.
This will be my last response to you here.
My apologies to Joey.
juanbenae 04-02-2019 05:13 PM
I knew I should have quoted the 2nd post you deleted before you actually did so.
Rawknees'Turbo 04-02-2019 05:20 PM
I saw a post by pNutz was made in this thread, and a few mins later I saw that caveman Toby had just posted, so I knew I needed to come-a-lookin' - glad I did! :D
juanbenae 04-02-2019 05:54 PM
you my friend have the face, ears and the nose of a blue trackin hound....
Rawknees'Turbo 04-02-2019 05:59 PM
And the libido, too!!! :eek:
pmax 04-02-2019 10:18 PM
OK, back on topic ...
It's a mystery alright.
What does the area around the fuel filter look like ?
JoeyD1005 04-03-2019 05:16 AM
hey Pmax,
Put on my detective hat yesterday and through some inspection in the engine bay and some creative image searching on the internet I believe I have a accurate picture.
So as a previous post of mine mentioned, I ran the numbers from the engine and it turns out that it is a 3.0 motor from a 1980 car that is currently in my 78. This engine originally had Lambda circuitry on the CIS which is verified by the tag on my FD (077). Whoever did this engine swap did a few things to make it work, hats off to creativity i guess.
1) never installed the lambda circuitry into the car as there is no leads for the relay box under the passanger seat or anywhere in the engine bay. There is also no o2 sensor port on the exhaust so he probably used the heat exchangers/exhaust from the original motor.
2) The mystery hose is in fact the exit of a secondary return line that on a 1980 motor would have exited on the back of the FD and then through a frequency valve before meeting the mystery hose and running back to the tank return. The mechanic has blocked the port on the FD as well as plugged the hose which I took a picture of earlier. So as far as I can tell, this engine was more or less back dated to pre-lambda system.
3) The WUR is from a 77 2.7 motor I believe being an 033 model. Im also unsure if the vacuum enrichment is routed correctly as when I took the port off while the car is running, the idle didn't change at all. But all that being said, it looks like the mechanic had then adjusted the mixture to get it all to run.
That leads me to where I am now.
So I guess the next questions we need to answer are:
1) Will simply replacing the WUR to the correct model be sufficient?
2) I know the WUR and FD typically are a matched pair, but I wonder if the modifications that the mechanic did to the FD will mean that I can continue to use a 045 wur as originally thought.
3) Is the vacuum enrichment routing on the WUR correct? (Does the throttle body have ports for both vacuum as well as manifold bypass?)
4) Any vacuum leaks? (i'll plan on building a smoke machine this weekend and doing a smoke test I suppose)
Then after all that is sorted, I guess its time to putz with the mixture/idle.
What are your thoughts?
-Joe
pmax 04-03-2019 11:26 AM
That's one mixed system with mismatching parts and non standard routing. The 80 FD runs lean without the FV, I believe, so the perhaps the mixture has been adjusted to compensate. The 80 TB doesn't have the same ports as the 78 so who knows how it will work with the 033/045 WURs.
If you ask me, I would install an AFR sensor to measure how and where it's operating at before tweaking the mixture. Hard to tell at this time where that is.
JoeyD1005 04-03-2019 06:06 PM
I agree with you Pmax, I actually have a wide band sitting on my bench that I can weld in a bung for.
On a bit of a different note, if I drop the motor and source the correct parts, is it possible to back date the CIS system to a complete Pre-lambda system? I.e. The correct 045 WUR and FD pairing? Then verify that vacuum lines are routed correctly? My goal is to not bastardize the system any more than it already has and fix it the right way.
Ideally, I'd like to just backdate the CIS system and have everything running as it should and reliably.
Since it was running correctly last season I'm guessing something shat the bed over the winter. Going to do a vacuum smoke test on her this weekend time permitting. Maybe thatll point me in the right direction, although I sort of felt I ruled that out previously. Who knows.
-Joe
