Caveman Hammer Mechanic
ClickClickBoom's Avatar
Smugglers Box Openings
Just like I said, the opening around the steering shaft, and brake lines is open to the ground. My query is, was this the way the factory intended? It seems that this opening channels air, cold or hot, right up to the instrument panel area. This might even explain the gauge fogging issue.
So the big question is how to seal that area from the outside environment/rats/mice, ect. I can cut and bend sheetmetal, but would prefer to use the factory solution, if there is one.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-01-2019, 10:08 AM
That is why there is a lid on the smugglers box. It should keep the major part of any air down in the box. You can't get to restrictive around the steering shaft. Make sure the lid fits tight, and the carpet for the trunk is on top.
I have never heard of an additional seal.
Last November I drove my 85 from OKC to Eureka Springs, Arkansas in rain. I never shut the wipers off. I did have them in delay mode for a while, but it rained for the entire trip. My gauges never fogged up.
Old 04-01-2019, 10:47 AM
wayner's Avatar
It was vented so that you gas heater inside would be less likely to explode
SOLD - 914 wide body hot rod
Old 04-01-2019, 11:05 AM
cycling has-been
bkreigsr's Avatar
I cut a couple of pieces of acoustic DynaMat to size.
Peel, stick, done.
Bill K
Old 04-01-2019, 11:25 AM
proporsche's Avatar
as Wayner said....this was inside on early 911`s ..Webasto gas heater
ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-01-2019, 11:35 AM
wayner's Avatar
Do newer cars still have the exhaust pipe welded in and louvers stamped out?
Old 04-01-2019, 12:07 PM
Its strange, the area to the left of the steering shaft is completely open, I could stick my fist though though the opening. The area around the steering shaft leads right up to the dash area. I can feel wind flowing around the gauge area. Guess I am gonna have to start some sheet metal work. Having that much open area is like having a open house sign for the rats/mice.
Old 04-01-2019, 02:58 PM
I stuffed a rag in there
Old 04-01-2019, 03:25 PM
On later cars with factory AC the evaporator lines are run next to the steering column out out to the bottom as well.
Old 04-01-2019, 04:48 PM
wayner's Avatar
On my old car, without air conditioning, I pop out my clock when I need cool air
Old 04-01-2019, 06:04 PM
I ripped my old non functioning a/c stuff out awhile ago, I guess now I get to fill the last holes.
Old 04-01-2019, 08:11 PM
I filled the large area with a piece of 1/8” silicone sheet cut to fit, and riveted in place, and sealed with body seam seal goop. It’s been drying for a couple days. Plenty of climbing in and out of the frunk making puppets for shaping.
Old 06-29-2019, 11:39 PM
E Sully's Avatar
There are 2 seals for LWB smugglers box openings. One metal and one I believe was fiberboard(901 504 747 00). In the photo I found on the web, a rubber seal is substituted for 901 504 747 00
Ed
1973.5 T
Old 06-30-2019, 06:20 AM
Harpo's Avatar
My 74 is wide open as well. Some day if it is ever on a roticery I will make up a sheet metal patch.
Old 06-30-2019, 06:26 AM
I have a 1988 3.2 that had the same problem. I don't know if the hole in your 74 is the same diameter. Got the cap from local big hardware store, they had a bunch of different sizes. About $5.00
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 06-30-2019, 09:21 AM
I used a plastic container that use to have Thai takeout in it. Strapped on with a hose clamp
ken
87 targa
Old 06-30-2019, 07:16 PM
This:
Old 06-30-2019, 08:36 PM
piscator's Avatar
Pool Noodles!?
Robert
"A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe)
Old 07-02-2019, 07:08 AM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
Originally Posted by ClickClickBoom View Post
This:
Nice. I used mesh, but this is a lot cleaner...
Old 07-02-2019, 07:39 AM
JED
ARCSinAK's Avatar
I am facing the same issue in my 74. I assumed the factory rubber gasket was long gone however the parts diagram list nothing. Strange that the Gmen never designed a flexible seal for the hole in the tub were the steering rack travels through. Nice work ClickClickBoom, want make another one?
Old 07-04-2019, 01:08 AM
