Turn Signals
Perhaps I can get some help with this:
Left hand turn signals work fine.
The emergency flashers work on the left side only.
Right hand the signal lights come on but do not blink, however the blinking sound does.
All bulbs have been replaced with new.
Any help appreciated.
Old 04-03-2019, 09:57 AM
JSZ JSZ is online now
I had the same issues on my car. Turned out it was the ground adjacent to the light housing needed to be cleaned very well and then reinstalled. I cleaned both body and wire eyelets and installed dielectric grease.
Give it a shot.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 04-03-2019, 10:19 AM
Thank you I’ll try that
Old 04-05-2019, 06:39 AM
New-ish 911SC Targa Owner
pampadori's Avatar
CHeck that your two-filiment bulbs (like the rear brake/parking light bulbs) aren't installed 180 degrees off. That gave my car some unusual lighting outcomes where lights that weren't even in that circuit would flash. I was about to light a bundle of sage and try to exercise the demons out of the car when i checked them again and found the issue.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 04-05-2019, 08:32 AM
Recreational User
porschenut's Avatar
That's very odd. It shouldn't even be possible to install them that way. That's why the little teats on the side of the lamp base are offset to match the offset slots in the lamp sockets. They can only fit securely one way. Maybe the lamps or sockets you were dealing with were old ones that didn't have this feature.
Old 04-05-2019, 12:11 PM
Yes, check proper bulb contacts and grounds.
Old 04-05-2019, 01:01 PM
