Odd Start Issue
I have a stock 83sc that has been great for several years now, no issues. On Saturday, the car wouldn’t start at first. It turned over for several attempts but did not start. I then feathered the gas pedal (which I never do) and the car started, sputtered a bit and leveled out. It ran for a minute or so, then cut out as if I turned the key off. It wouldn’t start again.
So, my first thought was a CDI failure. I checked for spark at the coil and plug wire #6 (random choice), all good there. Next, I pulled a plug and noticed it was dry. Hmmm…no fuel? I then pulled the red fuel pump relay and bypassed it with a switch (30, 87a). The fuel pump sounded good, I let it run for several seconds and I turned the ignition switch on and the car fired right up. After a few minutes I turned it off and put the red relay back in. I then started the car again, it fired right up. Took it for a ride and it ran great.
Next day, I started the car again. It didn’t fire right up but it did start after several seconds. Usually it just starts immediately.
The CIS components in the car are all relatively new/rebuilt as I went through the system a few years ago (Tony’s rebuilt WUR, new accumulator, fuel filter, injectors and seals, AAR, etc..)
At this point I am a little leery about driving the car somewhere and shutting it off. Does this sound like a bad check valve? Bad red relay?
Any thoughts on what the issue might be?
Thanks in advance!
Lou
Old 04-08-2019, 10:40 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Fuel pump? Cracked airbox allowing vacuum leak? These two issues caused me similar slow to start issues on my 83 3.0 before i up-converted to EFI.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 04-08-2019, 12:02 PM
Thanks for the response. It could be the fuel pump but odd that when I bypassed the red relay the pump operated fine.
I don't think it's a vacuum leak because they don't come and go.
The spark plug was dry when pulled which tells me it's a fuel delivery problem. As well as when I ran the fuel pump for several seconds the car started right up.
What does the fuel check valve do? I thought it kept the pressure in the line and prevented back flow. Is that correct? If so, wouldn't that fit this symptom I experienced?
Lou
Old 04-08-2019, 05:53 PM
T77911S's Avatar
its probably the relay.
when you bypassed it you primed the system which is why it started after you put it back in.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-09-2019, 04:16 AM
I agree but it started the next day as well. Is that still pointing at the relay?
Lou
Old 04-09-2019, 04:22 PM
T77911S's Avatar
that and/or I would check residual pressures
also spin the fuel pump fuse to clean it
RACE CAR:: sold
Old 04-10-2019, 03:53 AM
Okay, solved the cold start issue, thermo-time switch is faulty.
It appears I have another more serious issue. The car starts, runs for a minute or 2 then cuts out as if I turned the ignition off! It will not start again unless I let it sit for a day or so then it fires up and does the same "cut-out" again.
I tested the ignition switch, power on pin 15 of CDI unit. The fuel pump runs when I lift up on the plunger or bypass the relay (30, 87a), I replaced the red relay with a new relay, same issue. It appears to be spark just cutting out but not sure.
My question...what is the usual culprit of a car that just shuts off mid run without any warning? I'm thinking my CDI unit but am looking for clarification on this. Does a CDI box work then not work then work again? If it just died it would be easier for me to figure out...
BTW my CDI is a permatune. Have had it for years now (10 years maybe).
Lou
Old 04-28-2019, 06:09 AM
Prematune units will work intermittently- generally heat soak will cause them to stop working and then when they cool down will work again- maddening.
Keep a timing light handy to check when it happens.
Rutager West
Old 04-28-2019, 08:04 AM
Thanks rwest. I'm pursuing the CDI first. Will let you know what happens.
Old 04-29-2019, 06:54 PM
CDI loaner..........
Lou,
Do you need to borrow a 6-pin Bosch CDI? I have a dozen Bosch CDI units that I use for my troubleshooting. You could use the one that is installed in my engine test stand or the one in my car. PM me your address.
Send it back to me when you are done with it. I don’t know how to test and evaluate a CDI so I just use the ones that were tested/ran in previous engine start-ups.
Tony
Old 04-29-2019, 07:18 PM
Tony,
Thank you for the generous offer, I appreciate it.
I just sent my CDI unit to Bob Ashlock to be tested and repaired if necessary.
I'll let you know what happens.
Lou
Old 04-30-2019, 05:12 AM
I received my rebuilt Bosch CDI unit from Bob Ashlock (great guy and super helpful) and installed it on Friday. I have been running the car for a few days now and the "cut out" problem appears to be gone.
Thanks all for the responses.
Much appreciated.
Lou
Old 05-13-2019, 01:31 PM
Fahren mit dem Wind.
mhackney's Avatar
Hey Lou, did you get your issue sorted? I'm always available if you want to stop by!
cheers,
Michael
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-04-2019, 05:47 AM
Hi Michael,
It appears to be sorted out, thank you. Been a while since I've seen you. You should stop by and check out my 68 project that I've been working on.
Lou
Old 06-04-2019, 09:10 AM
mhackney's Avatar
Oh cool! That would be great. Are you around this weekend?
Caregiver to:
Old 06-04-2019, 09:25 AM
I should be around most of the weekend. I'll shoot you a text message.
Lou
Old 06-04-2019, 09:46 AM
Wrong picture attached..........
Originally Posted by boyt911sc View Post
Lou,
Tony
I just noticed today that I attached the wrong picture. The picture I posted earlier was that of the ECU’s for SC’s and nobody seemed to notice the blunder. Anyway, here are the Bosch CDI’s:
Tony
Old 06-04-2019, 10:48 AM
Tony,
I did notice. Thought maybe you were testing me to see if I knew the difference
Lou
Old 06-04-2019, 01:02 PM
