Can you convert a mechanical odometer 915 transmission to electronic
Can a 915 mechanical speedometer be converted to electronic?
Old 04-18-2019, 05:01 PM
Sure.
Basically what you could do is attach a flying magnet to the Inner CV flange, and mount a Hall effect sensor nearby to pick up the signal. Then read that signal with an Arduino, and use that to drive a stepper motor in a Speedo.
That’s basically what I’m doing in my 76.
Sent from my iPad using Tapatalk Pro
Old 04-18-2019, 05:21 PM
Under the radar
Trackrash's Avatar
Are you trying to put an older 915 in a newer car? What years? You may have other issues beside the speedo.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-18-2019, 07:11 PM
I did this in my 1975 car. I simply purchased an auto meter GPS sensor, and plugged it into an electronic Speedometer for my 911. It gives me really accurate speed, and works perfect.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 04-18-2019, 07:15 PM
It's in the car already
It's a 77 911s with a 74 915 transmission, it in the car already but I guess who ever did the transplant did not convert it.
Old 04-18-2019, 07:38 PM
Part number
Can you send me a link or part number please.
Old 04-18-2019, 07:39 PM
gearhead
Buy a 74 speedo and cable.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-18-2019, 08:31 PM
I thought about that but I just wanted to see if there was an easier way, thanks.
Old 04-20-2019, 02:13 PM
yellow box converter
https://yellr dot com
what i have on my 72
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-21-2019, 06:14 AM
