wannaporsche
No Turn Signal 'Clicking' noise in my 80SC
My turn signals and hazard lights operate properly, with the exception of the fact that they don't make any noise every since I've had the car (5 years). Wondering if the turn signal 'clicking' noise I'm used to on other cars is supposed to be there in my SC.
Also (possibly this is related?) there is no 'door open/key in' or 'fasten seat belt' warning buzzers in my car. All and all it's pretty quiet in there. It seems a previous owner may have silenced the noises. Can someone tell me what creates those function noises normally?
________________________ Tim 1980 SC Sunroof Coupe 2006 A4 Quattro 6 spd manual |
The turn signal click is faint. And you probably have the door/belt buzzer disconnected; the latter is under the dash on the left side of the steering column.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
turn signal click is almost silent on my car too, 1981 SC...i got used to it
before: '69 Porsche 911T bahama yellow now: 1981 911 SC Targa winered |
can you also help me with my turn signal, relay just buzz. yes I have changed to LED changed the relay to electronic relay, if that mean anything.
"IGNITION LEFT OF STEERING" Alex |
When I installed a new flasher relay I noticed that it was much quieter than the old one. (The old one was flashing too fast). However I laid the relay over a nearby black heating "box" and it is now louder with the "box" acting as a sounding box.
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
1986 Bosch Icon Wipers coupe. |
If the turnsignals work correctly w/o noise it could be that the flasher relay was replaced with a solid state unit or the flasher relay was moved towards the front trunk or wrapped in some sort of sound insulation material.
The clicking sound is a physical relay opening and closing.
Find Spoke's LED Products: www.spokeworksled.com |
