(man/dude)
Jonny042's Avatar
Source for proper heavyweight engine compartment sound pad?
I've purchased a few different ones (aftermarket and factory replacement) over the years and basically these have all been useless for the intended purpose, they are basically a lighweight foam with a vinyl skin on one side. Good for hiding the glue mess and easy to install, but scientifically speaking I would say no better than nothing at all for blocking engine noise.
I'm looking for a proper, heavy, pad, like was originally installed on my 87. I'll give up a pound or two to quieten things down a bit.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-24-2019, 07:29 AM
Once in a while I get lucky and find one at worldpac. Usually get the gray foam ones with a black coating, but sometimes the original style comes . Same part number, so you never know what you're going to get.
206 637 4071
Old 04-24-2019, 07:40 AM
sp_cs's Avatar
Rosepassion.con have them
Shirish
1987 Carrera, Granite Green
Old 04-24-2019, 08:44 AM
I don't know if this is any better but it's a bookmark I have waiting for the seal/clutch replacement. I tore the bits of the crispy one out but not going to attempt a replacement until there is room for my big mitts.
Can't post the URL as it's probably violating usage rules for PP. Check out Aasesales if that's allowed?
Old 04-24-2019, 08:45 AM
(man/dude)
Jonny042's Avatar
Thanks all, I should have checked our host before posting the question - they have a few different listings and one is described as "heavier weight" and has a correspondingly hefty shipping weight.
Will report back.
Old 04-25-2019, 05:57 AM
lateapex911's Avatar
Bump. Mine disintegrated years ago, and I'm due, and...my engine is out. ANy report on the success?
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-09-2020, 08:40 PM
Arlo911's Avatar
The rosepassion ones are the early type, more like heavy felt. You need the heavy rubber skinned one, correct?
Old 04-09-2020, 11:37 PM
(man/dude)
Jonny042's Avatar
Somehow I got busy doing other things...... so, no, sorry, I never followed through on this.
Old 04-10-2020, 05:59 AM
I'm good with tools.
AG81's Avatar
Will report back.
Jonny,
I used the heavier weight one when I had my stuff torn down in 2018. I was very please with the quality. Nice and thick
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 04-10-2020, 06:02 AM
(man/dude)
Jonny042's Avatar
Originally Posted by AG81 View Post
Jonny,
Was it the "hefty" version from PP? I do still have to do this on my 87, but "The Project" has been keeping me too busy!
(EDIT/PS - that's a nice tidy engine compartment! The 3.2 can really be cleaned up by removing a few things!)
Old 04-10-2020, 02:31 PM
Bill Douglas's Avatar
Then I tore my 1982 SC spare car parts to bits it had a big sound pad thing that went under the carpet and seats in the back of the car. Heavy, but I bet it worked to keep tire noise from the back wheels down as well as the engine plus exhaust.
Old 04-10-2020, 02:37 PM
