Distributor without ability to turn
I'm trying to adjust the ignition timing on my 1971 911T (which seems to be completely off). Though my distributor doesn't seem to have the ability to turn to make the adjustment. Instead the distributor is just fastened by a bolt, like the picture in the Haynes book.
How to I adjust the timing on this kind of distributor when I cant advance or retard the timing by loosening the bolt and turning the distributor?
Niels Kristian Bitsch
'71 911T Targa
'71 911S Targa wreck <-- to be completely renovated one day
Old 09-13-2016, 02:20 PM
You adjust timing by loosening the clamp under the distributor body, allowing the unit to rotate.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-13-2016, 02:30 PM
Hi Steve.
What clamp is that? Could you help me pointing it out on the picture?
'71 911T Targa
Old 09-13-2016, 10:16 PM
Jonny H's Avatar
In your picture, the clamp is touching the bottom of the red circle.
www.classicretrofit.com
Old 09-13-2016, 11:09 PM
That makes perfect sense.
So I just have to loosen this screw, that loosens the clamp right?
I tried to search around to find the solution, but everything pointed at the bolt.
How come that this distributor is different from the majority? Is it a very old design, or a newer one?
'71 911T Targa
Old 09-14-2016, 04:49 AM
That screw, if I remember correctly, is what turns the distributor clockwise or counter clockwise. The 13mm nut (M8) is what holds down the distributor once it is in the right position.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-14-2016, 07:36 AM
tobluforu's Avatar
Is that a marelli?
Old 09-14-2016, 09:18 AM
Originally Posted by tobluforu View Post
Is that a marelli?
No, it's a Bosch. Here's a picture of the actual unit:
I noticed that the previous owner blocked the vacuum port. Does this has anything to say when adjusting the timing? Should it still be 5 degree ATDC at idle?
'71 911T Targa
Old 09-14-2016, 09:22 AM
Revisiting this thread as I'm now struggling with this. Mine is a '71 2.2E in a 914, so I'm working on this blind. I've loosened the horizontal bolt pointed to by the white arrow, but I still can't rotate the distributor.
Old 04-22-2019, 04:10 PM
It's a Marelli,,,and its stuck, more force required.
Old 04-22-2019, 04:31 PM
Mine is actually a Bosch with the same clamp, but thanks so much for the advice. I ended up loosening said bolt, spraying the clamp with PB Blaster, and then driving around to heat up the motor and ultimately loosen the distributor so that it could rotate.
This forum rules.
Old 04-27-2019, 06:23 PM
