Pirate Rhum
Help identifying function
Greetings colleagues,
I have been doing some much needed house cleaning in the engine compartment and came across two open wires. Not sure if I knocked it off a connection? It looks as if the other half of the plastic housing is missing from it as well. Thanks for the help. (Pics listed below) Amir ![]()
911% lifestyle |
If it’s a 78/79 it, goes to a pod on the blower fan base above #3 runner
If it 80/83 it gets taped off, not used. Bruce |
Pirate Rhum
Thank you Bruce
It's 82.
911% lifestyle |
Yellow and brown would be the blower. Thermo-time switch for the warmup regulator vacuum would be my guess.
ROW '78 911 Targa
Wire colors would help. If brown and red/white then John Walker was correct.
Not used on US cars after ‘79 but be aware the red/white is energized with ignition on. Tape it up very well (red/white isolated) separate from the brown wire and tuck them out of the way securely.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 04-29-2019 at 01:17 AM.. |
