Born to Lose, Live to Win
ramonesfreak's Avatar
removing shift rod bracket
I need to replace the shift rod bracket and busing.
following the 101 projects book, it makes no mention at all how to remove this bracket...only that it is held on by two screws.....
I assume the ball cup has to come off....i see an allen screw in the side of the ball cup. Do I loosen that and pull of ball cup?
THanks
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-03-2019, 02:27 PM
Put the car into 3rd gear. Remove the shifter base by taking out the five bolts on the shifter base. Once the shifter base is off the bracket will have play in it. Find the allen head bolt on the driver side of the ball cup. Remove allen head bolt and slide ball cup forward to remove. Now slide the bracket + bushing out of the shifter rod.
95 993 C2
Old 05-03-2019, 04:29 PM
Thanks for the help!
1983 911sc
Old 05-04-2019, 06:04 AM
