Clutch didn't return, dropped engine/transmission to look inside
Hey folks,
I had a failure where the clutch went to the floor and wouldn't return unless forced. The clutch release lever would not return to the engaged position. I dropped the engine and removed the transmission. The fork seems in good shape, but some of the other components didn't look right. Here is what I found inside. ![]() ![]() ![]() ![]() ![]() ![]() Something looks wrong with the loose ring inside the clutch plate and on the transmission input shaft. I'm also not sure if the ring the fork engages looks OK. Any advice or ideas are appreciated - thanks!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Throw out bearing.
Looks like your throwout bearing has come apart. Novice myself. Here is a pic of mine when I split transmission and engine.
Good luck. |
Blamecanada - good picture. Here's a similar picture of mine:
![]() It's possible that your throwout bearing just broke from old age and use, but double check the fork that it is not broken. Mine broke on the back side and was very difficult to see when it was mounted on the car. ![]() You can see the top leg of the clutch fork has a crack in it. As you push on the clutch pedal, the asymmetric force on the throwout bearing will destroy it.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL Last edited by Walter_Middie; 05-04-2019 at 03:13 PM.. |
Thanks for the input guys. I took a bunch of high quality pictures of your fork, and it looks good.
I'm going to look up how to replace the throwout bearing . I didn't find anything helpful in the clutch replacement article on our host. ![]() ![]() ![]()
A few questions for the experts:
1) My clutch fork is hard to rotate on its shaft. I almost can't push it with one hand, without bracing my grip against something else. Should it be hard to move? Maybe its bearing is going out? 2) Regarding the old bearing (Release? Throw out? Not sure which it is called.) that was loose when I opened the car - is it broken entirely? Or some parts reusable? 3) Is there anything else I should serious consider replacing while I'm in here?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. Last edited by OsoMoore; 05-04-2019 at 04:05 PM.. |
Porsche calls it a clutch release bearing. Yours looks pooched. Think it comes with everything when you purchase it. The shaft the fork pivots on is clutch release shaft. It rotates on three bushings. You can remove the fork with a 4mm drift to drive out the split pin. Clean the shaft and grease it while probably help it move more smoothly.
You should be able to move that shaft with your fingers. If not, it needs service.
Your Throw out bearing is gone, it needs to be replaced and put back on the pressure plate. Depending on the condition of your pressure plate an clutch, you might need to replace those too.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
AutoBahned
wood nymph's hair is close but not a perfect match to car's paint
while yer in there... reach behind the fork with a bent probe and run it around to search for any cracks on that side measure end of the forks for wear I bet somebody did work w/o replacing the TO bearing - always a good precaution to toss those... use a high temperature grease on everything in there - you won't a color that won't run... |
Throwout Bearing
Your throwout bearing appears to be shot...
Normally replaced when the clutch pack is replaced - but if your clutch & pressure plate are in good shape, you can just replace the throwout bearing and reinstall. Good luck.
Don "Gordo" Gordon '83 911SC Targa |
At this point, drive out the roll pin on the fingers and drop the vertical shaft out of the bell
Remove the piñ on the long idler spring clutch arm. It’s tapered, only droves one way. Lose the pin. What i do is use a small Allen to hold the fork in place on the vertical and hammer the roll pin in displacing the Allen. Remove the long Arm and clean and lube everything. The measurement across the fingers for the throw out bearing is 75mm. Bruce |
replace the clutch guide tube, as well, while you have it apart. It may just be the light but yours looks to be showing some wear. That will affect smooth clutch/pedal movement, as well
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
the sticky pivot is what most likely toasted the throwout bearing. It kept too much pressure on it like resting your foot on the pedal all the time
82 SC , 72 914 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() EDIT: Nevermind, wrong tube. Is see what you mean, I'll re-inspect.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. Last edited by OsoMoore; 05-05-2019 at 05:04 PM.. |
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
You will need to drive out this pin in order to get the lever off of the rod. Clean and lube it so that it spins freely on the shaft. No need to replace the pin if you don't want to. I left mine out and just squirt some lube in the hole once in a while.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
To get the guide out you need a piece of heavy wire. Think welding rod stiff. You need to put a hook on either end and bend it semi circle(ish). Each hook goes into small holes at end of tube. Now use this loop to pry with a screwdriver or something similar against the end of the output shaft.
Take the two phillips screws out first. Takes a little effort but not bad. |
The wear doesn’t look too bad on your fork to me. Clean it out good inside the bushings where the shaft you took out rides before greasing. I just did a partial tranny rebuild and some minor work on my 915/3.0. So much too clean.
The clutch and T/O bearing were still serviceable but I opted to replace them since I was already " there". I manually re-surfaced the pressure plate and flywheel as there was no apparent damage other than dirt. I automatically replaced the pilot bearing and the throw out bearing. The T/O bearing guide tube had noticeable wear on it I removed the T/O bearing actuating shaft, cleaned and regreased it with multipurpose grease. Someone mentioned high temp grease and that can't be a bad idea. I also replaced all three seals on the T/O bearing actuating shaft. Inexpensive and now is the time to do it. Here is a caveat. While replacing the T/O bearing guide tube you should also replace the transmission input shaft seal but be careful You must either empty the transmission of its oil or support the transmission such that the input shaft is pointing upward. Other wise you will end up with just another mess. Another thing to consider, after you have serviced the T/O bearing actuating shaft and have it re-installed in location, be sure to properly locate the omega spring while the transmission is on the floor, (bench, kitchen table) as it will be so much easier than trying to do it after the transmission is in the vehicle. Good luck. Hugh Last edited by hughc; 05-05-2019 at 11:32 PM.. Reason: Not well explsonefù |
Red Line Service
Change the fork, change the fork, change the fork. Enough said!
Marc Bixen/Red Line Service West Los Angeles, Ca. www.redlneservice.net / info@redlineservice.net Podcast:"Marc Bixen Live" https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA |
