Help identifying part
I found this line among some 930 cis parts but I can't figure out what it is for or where it goes. I don't recall seeing a line this on a cis 930. One end has an 8 mm fitting and the other end has a 10 mm fitting. Any ideas? Thanks for looking.
lake wales fla
I honestly cant remember where i got the one i have in the picture that i included but i seem to recall it was a porsche motosports part possibly used on the 930 S I am not 100 % sure about that and there is a possibility it may be a RUF piece, but i can still see it in my minds eye bolted to the air flow sensor housing just to the right of the FD. and hooked up to the WUR I will try and look for some pics of motors i have built in the past to see if i can shed a little more light on it. For some reason i keep thinking i had a conversation about that part with Joe Enselmo not to many years ago, if your really wanting to find out get in touch with him @ Joe Enselmo Motorsports or talk to Bob Holcombe @ MODE i think one of them would remember. hope this helps to answer your question Richard
Looks like the injection line to cylinder one or two on turbo.
Bruce |
lake wales fla
If it is an injection line which is very possible it looks to me like a R.S bank 4-6 for a later sc i could not find any pics of the line that i referenced in my first post but did a little research and if you go into PET, look at 1987 911, illustration 107-35, position 36,37, and 39 you will see the damper and lines used on a 911 turbo with engine option M148 with engine designation 930.66 S I am not sure if that line is the same one the OP is asking about but looks very similar, but after closer look the OP line resembles a later sc injector line. His comment that he found the line with 930 parts led me to think it was a 930 part which may be incorrect. |
Thank you both for the replies. I appreciate it. My 930 has the larger cis fuel lines but I know the later model 930.68 930's had the smaller diameter lines. This line is too short to be used as a fuel distributor to injector line. I don't know much about SC cis but I will look into that.
