-   -   Window keeps coming out of track, found this part in the bottom of the door (http://forums.pelicanparts.com/porsche-911-technical-forum/1029907-window-keeps-coming-out-track-found-part-bottom-door.html)
rollandburn 05-18-2019 08:52 PM
Hi, my driver side window came out of the ‘clamp’ that scissors up and down inside the door. I pulled it all apart, reseated the window, couldn’t see a way to hold the window in place so just fit it in snug and did a few up and down tests. Seemed fine. I put it all back together, half hour later the window popped out again.
Also I found this cylinder at the bottom of the door, looks like the window would into the groove but I’m not sure where it might have come from.
Any ideas appreciated. https://uploads.tapatalk-cdn.com/201...3e6884a585.jpg
HarryD 05-18-2019 09:00 PM
The thing in your hand is the Pivot Pin. It allows you window regulator spring to operate your window. It has failed and needs replacement.
Do a search here with this term and find many threads on the topic.
The pin itself comes in four configurations and you need to get the correct one by measuring the size of the one you have and note the ends are perpendicular to each other.
HarryD 05-18-2019 09:07 PM
Thus thread may be helpful. http://forums.pelicanparts.com/porsche-911-technical-forum/639895-window-regulator.html
rollandburn 05-18-2019 09:36 PM
Wow that’s great fellas.... thanks a lot, really appreciate it!
john walker's workshop 05-19-2019 04:28 AM
Might have been from a previous regulator if yours still goes up and down.
cabmandone 05-19-2019 05:52 AM
What others have said... but with some pics. The bolt was my fix.
http://forums.pelicanparts.com/uploa...1558273769.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/807649-my-window-regulator-spring-retainer-slow-power-window-fix.html
Dpmulvan 05-19-2019 06:04 AM
There's always confusion when it comes to this piece. The part that's broken is not available you have to make one. The part that's available is for the center of the spring.
They are sometimes confused and both called pivot pins.
911tracker85 05-19-2019 06:06 AM
I just love to see people fabricate stuff for our old cars.
I go into a hardware store browsing the racks. guy asks me if he can help me find something. I tell him what I need to fab a part for an old porsche and he just walks away shaking his head.:D
sky1jord 05-19-2019 06:25 AM
Originally Posted by dpmulvan (Post 10463602)
there's always confusion when it comes to this piece. The part that's broken is not available you have to make one. The part that's available is for the center of the spring.
+1
HarryD 05-19-2019 07:40 AM
FWIW. The earlier cars like mine did not have the second pin. Not sure when it changed.
kent olsen 05-19-2019 08:51 AM
Over the years, 20 i've owned this 72, I've had several problems with the window coming out of the lift in the door. I know the issue is the window restriction in the door frame slots or slides, whatever you call it.
So rather than fix that I've just tried a better glue. Well most glues don't work well on glass so last month when it happened again I used a glue I use to patch the bottom of my little sailboat. It drys really hard so I'll see how it works but I really need to replace those rails or whatever they call them.
HarryD 05-19-2019 10:48 AM
Some pictures of Pivot pin locations:
1974 (no second pin)
Originally Posted by kiwiboyd (Post 2914831)
another pic....this one is on the way out
http://forums.pelicanparts.com/uploa...1162947571.jpg
1977 (no second pin)
Originally Posted by TMR (Post 1191694)
With the weather getting warmer I decided to try to fix my driver's side window that has been "slipping" while cranking. I got everything apart but I can’t figure out how to get the pivot pin out. I must be missing something obvious here. I would appreciate any assistance on how to get the pivot pin out of the window regulator.
http://forums.pelicanparts.com/uploa...1078023497.jpg
1980 (homemade second pin)
Originally Posted by grahamkissack (Post 5686182)
Ok...got it fixed.
Removing the regulator is like a ball joint ... why was that so hard. I ended up removing the power window motor to get it out...couldn't see any other way.
Here's the replacement bolt (with a low profile flat head and square shaft) that I stalled to hold the spring in place of the failed aluminum piece.
http://forums.pelicanparts.com/uploa...1290400329.jpg
http://forums.pelicanparts.com/uploa...1290400364.jpg
2008 replacement part:
Originally Posted by viscirid (Post 5064793)
So I have determined that my window regulator pivot pin broke off. Found the tell tale part in the bottom of my door. http://forums.pelicanparts.com/uploa...1260594225.jpg
And just to be clear, when everyone talks bout the window regulator pin, they mean part 1 in this diagram, not part 2 (center pin)? The spring uncoiled and hooked on 3.
http://forums.pelicanparts.com/uploa...1260594403.jpg
I just want to make sure that the part 910392 or 910394 is what I am looking for.
The real question is does anyone have a clue as to how to figure out if it is the 23 mm or the 26 mm? I went to check the other door and that one was unfortunately missing as well.
Any help would be appreciated.
Thanks.
V.
rollandburn 06-16-2019 01:36 PM
Ok so I finally found a bit of time, pulled everything out of the door.... I can’t see anything broken. It’s possible the pin I found in the bottom of the door was from a previous failure because I don’t see where it could be missing from.... the pins appear to be in place and everything works ok.
The last time I thought that, I reseated the window, buttoned everything back up and it popped out again.
Are there any other things I should look at? Could it be the dried out quality of the rubber in the channel that grabs the window, old and dry let’s go easily? I’m not sure I want to glue the window in the track like a previous poster.
https://uploads.tapatalk-cdn.com/201...8bfb85eeb0.jpg
https://uploads.tapatalk-cdn.com/201...12529c3539.jpg
mhackney 06-16-2019 01:42 PM
Likely the pivot had failed and a PO replace the mechanism and didn't do a good job seating the glass in the U channel.
Remove the rubber U from that channel and check the channel carefully to make sure it is not rusted badly. Mine was so it could not grip the rubber/glass. Clean the channel and rubber thoroughly. Ibn theory, the rubber is seated on the glass edge and then the rubber/glass is pressed into the U channel without adhesive. The glass/rubber really needs to be PRESSED into the channel. I did both sides of my 83 cab a few years ago and the windows work perfectly.
rollandburn 06-17-2019 08:11 PM
Welp, this time I pulled everything out of the door.... cleaned the track, scrubbed the rubber spotless, squeezed the track gently in a vice to close up the ‘mouth’ where the window sits, put the rubber on the window first as you suggested, made sure the fit was super snug after putting it all back together. No glue. So far so good.
It seems the track spread open at the top + the dry rubber was essentially letting go of the window when coming down. I didn’t think that could be it because the window falls easily with gravity, but that must have been it. I’m glad I learned all about the inside of the doors. I’m glad I didn’t have to spend money on a repair. But holy crap what a ****ty job... trying to get the track back into the door, get the regulator motor back in place, get window switches wired back up.... more of a pita than doing my suspension in its entirety. Lol... probably a 2 minute job for someone experienced. What I wouldn’t give to know the tricks of the assembly line trade. Oh well, it was a win-win in the end. Thank you so much for all your help pelicans!
Hi_Fi_Guy 06-17-2019 09:41 PM
Originally Posted by rollandburn (Post 10493849)
Ok so I finally found a bit of time, pulled everything out of the door.... I can’t see anything broken. .
There is a hole to the left of the spring in your photo where the pin goes. Unless your model is somehow different from the other examples shown.
rollandburn 06-18-2019 05:58 AM
You are correct, however the slot in the piece i found in my door should be for the tab in the centre of the spring to fit into no? Now I'm confused lol... I see the hole you're talking about and the other versions that have a pin there, but can't see what a pin in that location would in fact do... the window seems to be working fine now. :confused:
brighton911 06-18-2019 07:49 AM
With the pin in the correct hole, the spring acts like a counterweight to make it easier on the motor and associated parts. Yes, it will work in your current configuration but the window action will be slower and harder on the motor and it's transmission. The difficult part was getting the regulator out, the fix is now easy. A simple carriage bolt in the hole with two nuts (as others have done) is the 50 cent fix.
rollandburn 06-19-2019 02:26 PM
Hmmmm, I took a look across the web for pictures of Genuine Porsche Part: EL W-CRANK # 911 542 003 28 (the number on the crank in my door) and don’t see a pin in that hole on any of them. Admittedly some of the pics looked like used eBay parts which could be broken off to begin with but a few looked like new replacement parts. Our host doesn’t have a pic of that part number unfortunately.
I’m thinking the multiple versions of the crank might be confusing all of us lol. Hopefully I’m right, I really don’t want to open up the door again.
[emoji41]
Two pics I found of my part number sans that 3rd pin...
https://uploads.tapatalk-cdn.com/201...7d6a5f0bd2.jpg
https://uploads.tapatalk-cdn.com/201...83ebb2594b.jpg
Hi_Fi_Guy 06-19-2019 08:47 PM
Do the fix. It’s worth it. Takes a few minutes and then the window action is smooth like “butta”
